Vocal Romover Unavailable
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by Kvncln » Sat Nov 18, 2017 1:47 pm
Hi !
I've just download Audacity 2.1.0 for my Mac on macOS 10.12.6 and I don't have access to the Vocal Remover Plug-in on the Effect Menu ... I've tried to "install" or "add" the plug in vocalremover.ny present in the Audacity Folder but nothing happen ... Every plug in present in that folder are not install in Audacity, I just have the Audio Units ... :cry:
Thanks a lot for your help, have a nice day ! :D
Kvncln
Re: Vocal Romover Unavailable
Permanent link to this post Posted by steve » Sat Nov 18, 2017 2:54 pm
Kvncln wrote:I've just download Audacity 2.1.0 for my Mac on macOS 10.12.6
That's an old version.
The current version is 2.2.0 and is available via the Audacity website: https://www.audacityteam.org/download/mac/
The Vocal Remover effect is installed by default, though I would also suggest that you also try the new "Vocal Reduction and Isolation" effect. You can find out more about the new effect from the manual: http://manual.audacityteam.org/man/voca ... ation.html
Ensure that you install Audacity according to the instruction on the download page, otherwise many of the included effects will be unavailable.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
