Lowering audio's "highs"
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by writerhoward » Fri Nov 10, 2017 12:39 pm
I am listening to an instructional audio and every 10-15 seconds, the speaker's volume, very briefly, rises above a level I find comfortable listening to. How can I lower the "highs"? Related to that, how can I know how much to lower the highs? I am a novice using Audacity.
Also, the audio is an MP3. If I want save my changes, should I export it as MP3? If so, what export settings should I use?
Thanks,
Howard
writerhoward
Re: Lowering audio's "highs"
Permanent link to this post Posted by steve » Fri Nov 10, 2017 2:15 pm
Try using the Limiter effect http://manual.audacityteam.org/man/limiter.html
Reducing the peak level by 6 dB is equivalent to reducing the level by half. So, if you first Normalize (http://manual.audacityteam.org/man/normalize.html) to 0 dB and then set the Limiter to:
Type: Soft Limit (default)
Input Gain: both 0 (default)
Limit to (dB): -6
Hold: 10 (default)
and that will reduce peaks that are over -6 dB down to -6 dB.
Permanent link to this post Posted by writerhoward » Fri Nov 10, 2017 3:07 pm
Steve,
The audio is an MP3. If I want save my changes, should I export it as MP3? If so, what export settings should I use?
Howard
writerhoward
Permanent link to this post Posted by Trebor » Fri Nov 10, 2017 5:16 pm
writerhoward wrote: ... The audio is an MP3. If I want save my changes, should I export it as MP3? If so, what export settings should I use?
MP3 is a lossy format : there is accumulative damage by repeatedly using MP3.
If you must make an MP3 of an MP3 use the highest quality settings to minimize the loss.
Loss-less formats like WAV & FLAC are the best quality, but their file size is ~10x larger than MP3.
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
