Questions about slowing tempo
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by writerhoward » Thu Nov 09, 2017 1:17 pm
I am using Audacity 2.1.3. I am listening to an audio and the speaker is speaking too fast. I know that I can use "Playback Speed" to slow his speech, but in addition to doing that, if I also set the percent change in Effect | Change Tempo to -12%, will that change still work if I had changed Playback Speed to 82%. Can they work together? I am trying to find the best way to slow the speaker's pace.
Howard
writerhoward
Re: Questions about slowing tempo
Permanent link to this post Posted by steve » Thu Nov 09, 2017 4:44 pm
Whichever way will work to a point, but too much and it will be difficult to understand. You'll just have to try it and see what works best for you.
There's no reason why can't use "Change Tempo" and "Playback Speed" together, but note that "Playback Speed" is only temporary, whereas "Change Tempo" is an effect that permanently changes the audio (though "Ctr + Z" will undo the last used effect).
Permanent link to this post Posted by writerhoward » Thu Nov 09, 2017 5:22 pm
Thanks Steve.
I did not realize that when I exported my file to MP3 that only my "Change Tempo" change was part of the export.
Howard
writerhoward
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 11 guests
