Apply Chain not working - freezes
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by voshelley » Tue Nov 07, 2017 6:18 pm
I've just updated to 2.2.0 (Mac w/El Capitan) and cannot get 'apply chain' to work. Any time I apply a chain to the project, a square black screen pops up as well as the apple rainbow wheel, that cannot be reduced or placed behind any other window, until I 'force quit' the program. Doesn't seem to matter which chain I apply, the program crashes. I use chains on every project and had no issues with previous versions.
voshelley
Re: Apply Chain not working - freezes
Permanent link to this post Posted by waxcylinder » Tue Nov 07, 2017 6:48 pm
There is a crash issue with Chains in 2.2.0 which has already been fixed for 2.2.1.
If you're feeling bold you could try that latest 2.2.1 alpha nightly from here: https://www.fosshub.com/Audacity-Mac-Nightlies.html
It's actually pretty stable and well worth a try - please report back if your chain works with this version.
waxcylinder
Permanent link to this post Posted by voshelley » Tue Nov 07, 2017 6:54 pm
It works! Thanks so much for your prompt reply, and fix :)
voshelley
Permanent link to this post Posted by waxcylinder » Wed Nov 08, 2017 2:45 pm
Thnks for the feedback - good to hear that it works on your Mac,
waxcylinder
Permanent link to this post Posted by trish1206 » Tue Dec 05, 2017 1:57 pm
I am currently dealing with the problem of applying chains and it freezing the software.
So frustrating. I am an audiobook narrator and this research on how to fix the problem is
costing me, big time. I'm no computer engineer but I do okay.
Chains worked fine until I downloaded 2.2.0. I don't know what alpha nightlys are.
If someone could explain, I would be grateful. I have been using audacity for
a long time and I need the chains...
trish1206
Permanent link to this post Posted by steve » Tue Dec 05, 2017 3:41 pm
trish1206 wrote:I don't know what alpha nightlys are.
They are pre-release versions.
I'd suggest that you try "Audacity 2.2.1 RC2". This is the latest version, and although there will be an RC3 before 2.2.1 is released, that is only to update some documentation files. It is expected that the 2.2.1 release version of Audacity will be identical to RC2.
2.2.1 RC2 should fixes this problem in Chains, and it is available here: https://www.fosshub.com/Audacity-devel.html/
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
