Rattling behind voice in voice audio
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by Tab3 » Mon Nov 06, 2017 6:35 pm
Hey guys
I get this rattle behind the voice sometimes when using audacity. It seems to always start about 2-3 mins into a recording. I have tried different mics. It doesn't happen every recording but is annoying when it does! I cannot use noise reduction as the rattle seems to be generated only behind the voice audio.
I have a clip here so you can see what I mean.
What can I do to get rid of this?
sample.wav
(788.04 KiB) Downloaded 13 times
Tab3
Re: Rattling behind voice in voice audio
Permanent link to this post Posted by Trebor » Mon Nov 06, 2017 8:19 pm
If you zoom-in on the waveform you can see there are glitches ...
They could be "skipping", see ...
http://manual.audacityteam.org/man/faq_recording_troubleshooting.html#How_can_I_record_without_small_skips_or_duplications.3F
before-after DeClicker.flac
(290.06 KiB) Downloaded 11 times
Trebor
Permanent link to this post Posted by Tab3 » Tue Nov 07, 2017 1:49 am
Thank you. Is there anything I can do to salvage this audio?
Tab3
Permanent link to this post Posted by billw58 » Tue Nov 07, 2017 2:58 am
You might want to look at this FAQ:
http://manual.audacityteam.org/man/faq_ ... _on_Mac.3F
The problem of "clicky" recordings on Mac sometimes requires the counter-intuitive measure of reducing the "Buffer length" in Devices Preferences.
As to rescuing the recording, there is no simple method. All I can suggest is zooming in, finding each glitch, selecting a small region around it and doing Effect > Repair.
-- Bill
billw58
Permanent link to this post Posted by Trebor » Tue Nov 07, 2017 3:10 am
Tab3 wrote:...Is there anything I can do to salvage this audio?
You can use repair individually on each of the glitches, but that will take an eternity.
There is a DeClicker plugin for Audacity which does the all the repairs in one go, (it's slow but much quicker than by-hand).
Suggested DeClicker settings.png (26.5 KiB) Viewed 137 times
before-after DeClicker (1).flac
(290.06 KiB) Downloaded 10 times
Trebor
Permanent link to this post Posted by waxcylinder » Tue Nov 07, 2017 11:18 am
billw58 wrote:You might want to look at this FAQ:
-- Bill
Those glitches might (and I say "might") be picked up and fixedby Brian Davies; Click Repair app- you can try it for free for 14 days. See this sticky thread: viewtopic.php?f=28&t=1994
Update: I just did a quick test with ClickRepair on your sample - and it seemed to work quite well.
waxcylinder
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
