Very silent piece of audio. Compressor or???
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by Annelise » Mon Nov 06, 2017 10:44 am
Hello everyone.
I am new to audacity, so that is why I probably have no idea what to do.
I have read couple of notes about the envelope and compressor and even tried to normalise, but so far I haven't had much progress. On the contrary, I have had only 'jangling' loud sounds and very silent those, which are silent. I attach here the screenshot of the recording, so that you can see the difference between the loud and the silent peaks.
Can you recommend anything?
Screen Shot 2017-11-06 at 10.43.31.png (22.46 KiB) Viewed 163 times
Annelise
Re: Very silent piece of audio. Compressor or???
Permanent link to this post Posted by Trebor » Mon Nov 06, 2017 4:13 pm
http://manual.audacityteam.org/man/envelope_tool.html
If you make the very quiet sound much louder inevitably it will then be of lower quality than the un-amplified audio: more hiss, more conspicuous (jangling) digital artifacts. That's unavoidable.
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
