amplitude for 70db
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
amplitude for 70db
Permanent link to this post Posted by tinating9 » Mon Nov 06, 2017 6:43 am
I want to create a tone of 70db, 2000HZ for my psychology experiment. I am wondering which value I should put in the Amplitude (0-1) to control the loudness.
Many thanks,
Tina
tinating9
Re: amplitude for 70db
Permanent link to this post Posted by steve » Mon Nov 06, 2017 9:36 am
There is no way to control how loudly a file will play. Even a "quiet" audio file will sound loud if I play it via a big amplifier with the volume turned up high. Similarly a "loud" track will sound quiet if I turn down the playback volume.
To play a sound at a specified loudness, you would need a "Sound Pressure Level" meter ("SPL meter"), and adjust the playback volume of your audio playback system.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
