Changed speed not saved [SOLVED]
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by Arkadian » Thu Nov 02, 2017 9:47 am
Hi there,
new here, so I apologies in advance. I have searched the forum but having found nothing I gather it must be me...
Anyway, I have Audacity 2.1.3 on a Mac running 10.11.6.
I have imported into Audacity a track from a CD which I had copied onto my hard drive. I can open the track fine and I can vary the speed fine. However I then stop the track and when I save it going to File/Export Audio I get the original track, i.e. with the old speed.
How can I alter the speed of the track and save it so that I can burn it onto a CD for later use?
Thanks in advance ;)
Arkadian
Re: Changed speed not saved
Permanent link to this post Posted by steve » Thu Nov 02, 2017 10:08 am
I presume that you have been using the Transcription Toolbar to change the speed, but that only changes the speed of playback, it does not alter the actual audio at all. To change the audio you need to apply an effect - in this case the Change Speed effect.
Permanent link to this post Posted by Arkadian » Thu Nov 02, 2017 10:43 am
Apologies for the daft question.
All solved now :D
Arkadian
Re: Changed speed not saved [SOLVED]
Permanent link to this post Posted by steve » Thu Nov 02, 2017 11:47 am
No problem - it's easy when you know how ;)
I'll mark this topic as 'solved'.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
