Left/Right - Good when editing, Bad on output
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Re: Left/Right - Good when editing, Bad on output
Permanent link to this post Posted by kozikowski » Tue Oct 31, 2017 3:53 am
I'm with you. You have impossible symptoms. I should go back and read through that again. The only way you can get a clean playback is use non-wired speakers?
Nowhere did anybody write you can't have two problems.
There is no condition a good engineer can't make worse.
Permanent link to this post Posted by kozikowski » Tue Oct 31, 2017 3:55 am
it was three different headphones
You should start getting this stuff down to model numbers. All three made by the same company?
Permanent link to this post Posted by twitchmatic » Tue Oct 31, 2017 3:30 pm
So I tracked down my original headphones and they work fine. Sigh. The headphones I were using were fairly high end so I didn't even think to try the original headphones. Thanks again for leading me through some basic troubleshooting :)
twitchmatic
Permanent link to this post Posted by steve » Tue Oct 31, 2017 3:39 pm
twitchmatic wrote:The headphones I were using were fairly high end so I didn't even think to try the original headphones.
Were you using a jack adaptor with the high end headphones?
Permanent link to this post Posted by twitchmatic » Wed Nov 01, 2017 4:28 pm
I used a variety of two/three stripe jacks initially to try to figure it out - all of which had issues. In the end, I'm fairly certain there may be a laptop connector issue as wireless is fine (airplay) and the person I sent the file to file was able to enjoy it correctly. Phew. :)
twitchmatic
Permanent link to this post Posted by steve » Wed Nov 01, 2017 4:45 pm
twitchmatic wrote:I'm fairly certain there may be a laptop connector issue
Connector / adaptor are likely causes.
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
