Audacity working with an external mixer
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by Birger » Mon Oct 30, 2017 12:24 pm
I have tried to get the Audacity program to work with my Yamaha mixer for making song recordings with overdub - but it does not work. It won't record the singing and also the playback that goes via the Yamaha mixer is so low that you can't hardly hear - whereas when the playback goes on my Mac via external speaker it is fine?
Anybody with the same problem?
Birger
Birger
Re: Audacity working with an external mixer
Permanent link to this post Posted by kozikowski » Tue Oct 31, 2017 4:30 am
Which Yamaha Mixer? USB? Does it claim to have "Zero Latency Monitoring?
I use an analog mixer with a USB audio interface. The only trick is I have to listen to the interface, not the mixer, but I do hear both sides in Perfect Overdubbing.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
cron
