Audacity not recognizing FFmpeg library
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by foggy » Mon Oct 23, 2017 5:33 pm
Hello,
I have a Mac Mini server (Mid 2010, 2.66 GHz Intel Core 2 Duo, 8Mb RAM) running Mac OS Sierra 10.12.6 on a 525G solid state SATA drive.
I downloaded Audacity 2.1.0 and installed the FFmpeg Import/Export Library following these instructions.
I have repeated this process a dozen times: 1) Go to preferences / libraries and locate the file "libmp3lame.dylib." 2) Select the file located in /application support/audacity/libs/
Audacity never recognizes the file, with the preferences pane continueing to report that the FFmpeg libraries are not installed. I can restart the computer or Audacity, try it again, and the same thing happens. The file is in the proper location but when you "Browse" and locate the file, it just doesn't register in Audacity.
Today I downloaded Audacity 2.1.3 for MacOS and went through the same process, even deleting the old application support file and reinstalling the FFmpeg Import/Export Library. No dice.
I did a search in this forum on "libmp3lame.dylib" and found a half-dozen posts from Mac users who experienced the same thing, but the threads dead-end and seemingly never get resolved after the OP is quizzed about did you follow this instruction or that. This is definitely a bug.
foggy
Re: Audacity not recognizing FFmpeg library
Permanent link to this post Posted by billw58 » Mon Oct 23, 2017 8:16 pm
foggy wrote:Go to preferences / libraries and locate the file "libmp3lame.dylib.".
That's the wrong file. You need to find "libavformat.55.dylib".
The normal location for the FFmpeg shared libraries is /Library/Application Support/audacity/libs.
-- Bill
billw58
Permanent link to this post Posted by foggy » Mon Oct 23, 2017 8:50 pm
Does anyone else see a problem here?
I downloaded the first two items listed at the page all the documentation points to and they install libmp3lame.dylib. How is a user to know this?
foggy
Permanent link to this post Posted by billw58 » Tue Oct 24, 2017 3:36 pm
The page you reference contains:
FFMPEG (not for mp3 export)
FFmpeg 2.2.2 ZIP for Audacity 2.0.6 or later on OS X 10.4 and later (Intel or PPC):
Binary FFMPEG OSX Installer: DMG - ffmpeg-mac-2.2.2.dmg ffmpeg-mac-2.2.2.zip
You want to click on the link for the FFMPEG DMG file, which contains an installer.
The first two items on that page (which you say you have downloaded) are:
RECOMMENDED Installer Package for LAME on OSX:
Lame_Library_v3.99.5_for_Audacity_on_macOS.dmg
LAME on OSX ZIP version:
Lame_Library_v3.99.5_for_Audacity_on_macOS.zip
which are clearly for LAME, not FFmpeg.
I don't know why the Library preferences gives that message in the locate dialog. Mine doesn't.
That said, you can click the "Browse" button and find the required file.
Before this will work, though, you need to download the FFmpeg installer and run it. Otherwise the "libav*" files will not be on your computer.
If you still get a message telling you to find "libmp3lame.dylib" when you're trying to find the FFmpeg files, you may need to reset the Audacity preferences. This is done by going to ~/Library/Application Support/audacity and deleting the audacity.cfg file.
-- Bill
billw58
Permanent link to this post Posted by foggy » Tue Oct 24, 2017 5:20 pm
Bill,
Big Fail on my part not reading the diff between LAME and FFmpeg. Now installed properly, thanks for patience with a newbie.
P.S. adding the tetragram for "fail" causes an SQL error on phpBB, interesting.
foggy
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
