Noise Gate Plugin - not showing up in Effects Menu [SOLVED]
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: Noise Gate Plugin - not showing up in Effects Menu
Permanent link to this post Posted by skrebs » Fri Nov 10, 2017 4:53 pm
Hi,
I'm seeing a similar problem when trying to add the Acx-check.ny plug-in. Firstly there was no Plug-Ins folder in my /Library/Application Support/audacity/ folder so I created one. When I downloaded the Acx-check.ny plug-in and moved it to the Plug-Ins folder I could not see the plug-in under the the Analyze -> Add/Remove plug-ins... menu even if I restarted Audacity. I have version 2.2.0
Thanks
skrebs
Permanent link to this post Posted by billw58 » Fri Nov 10, 2017 8:48 pm
skrebs wrote:Hi,
Wrong folder. That's the system-wide folder. You want your user library folder, which is at ~/Library/Application Support/audacity/. The "~" character at the start is important.
-- Bill
billw58
Permanent link to this post Posted by skrebs » Sat Nov 11, 2017 7:02 pm
Thanks Bill. When I look under the Users folder and my account name there is no Library folder so perhaps I'm still looking in the wrong place.
Mark
skrebs
Permanent link to this post Posted by billw58 » Sun Nov 12, 2017 4:03 pm
Mac hides the user Library folder by default.
In the Finder, click the Go menu while holding down the option key. "Library" should appear as an option in the menu. Select it.
If that doesn't work, do Go > Go to Folder and type "~/Library/Application Support/audacity" into the dialog. Don't forget the "~" character at the start.
-- Bill
billw58
Re:Noise Gate Plugin not showing up in Effects Menu [SOLVED]
Permanent link to this post Posted by skrebs » Tue Nov 14, 2017 1:17 pm
Thanks very much Bill - that worked!
Mark
skrebs
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 8 guests
