Noise Gate Plugin - not showing up in Effects Menu [SOLVED]
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by Smita » Mon Oct 23, 2017 5:13 pm
Hello
I've just downloaded the Noise Gate file for Mac using the ZIP folder because the Download link only gives a text file and not the .ny file. This is the link:
http://wiki.audacityteam.org/wiki/Nyqui ... Noise_Gate
However, once I am putting the Noise Gate plugin file into Audacity Plugins folder, while it does show in the Plugins Folder, when I open Audacity (after having closed it down and reopening). I cannot see Noisegate in the Effects menu.
When I click in Add / Remove Plugins, to enable NoiseGate, again, I cannot find Noise Gate in the Effects drop down menu.
Please can you advise?
Kind Regards
Smita
Smita
Re: Noise Gate Plugin - not showing up in Effects Menu
Permanent link to this post Posted by Smita » Mon Oct 23, 2017 6:22 pm
Hi there
I'm using Mac OS Sierra Version 10.12.6
Tx
Smita
Smita
Permanent link to this post Posted by Smita » Mon Oct 23, 2017 6:26 pm
And I'm using Audacity Version 2.1.3.
Tx
Smita
Permanent link to this post Posted by kozikowski » Mon Oct 23, 2017 6:29 pm
Attached my copy of Noise Gate 3.0.
Noisegate.ny
(8.56 KiB) Downloaded 23 times
Permanent link to this post Posted by steve » Mon Oct 23, 2017 6:31 pm
Nyquist plugins are plain text files with ",ny" file extension. If macOS adds a ".txt" file extension you can just rename it back to "whatever.ny"
Permanent link to this post Posted by kozikowski » Mon Oct 23, 2017 6:32 pm
Or what I perceive to be versions 3. Versions and Revisions are different in Nyquist.
Permanent link to this post Posted by Smita » Mon Oct 23, 2017 6:51 pm
Thank you Koz - I reinstalled the version you sent but I'm still not seeing Noisegate in my Effects dropdown menu to enable it ...
I'm trying to clean up the sound re: breathing and clicks, etc. on a podcast without any background music.
Is there another simple and easy way I can do this without using Silence under Generate dropdown menu?
It's an hour long podcast and I don't want to go through each and every sentence.
Tx
Smita
Smita
Permanent link to this post Posted by djlonboy » Fri Nov 10, 2017 8:24 am
Hi there
I am having this problem too. I had a look at the online manual and it mentions going to Add / Remove Plugins to enable or disable installed plugins, but this menu item is completely missing under Effect, Generate and Analyze on my version of Audacity (2.1.0)
Thanks in advance for any assistance
djlonboy
Permanent link to this post Posted by waxcylinder » Fri Nov 10, 2017 2:41 pm
djlonboy wrote:Hi there
That's because 2.2.0 did not have that feature.
It came in with 2.1.1 and was called "Manage" then
In 2.1.2 the nomenclature was changed to the "Add/Remove Plug-ins
All of those versions are way out of date and superseded (Unless you are visually impaired and need screen reader functionality - in which case 2.1.1 is the current version).
I suggest you download the latest Audacity version 2.2.0 from here: http://www.audacityteam.org/download/mac/
waxcylinder
Permanent link to this post Posted by djlonboy » Fri Nov 10, 2017 3:30 pm
Thanks very much for your help. I'm not sure how I ended up with an old version of Audacity since I only installed it a few weeks ago! I must have clicked on the wrong link.
Thanks for your assistance :)
djlonboy
Next
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
