Vocal Remover Isolation Effect Not Available?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by Michael221 » Sat Oct 21, 2017 2:13 pm
Hello,
I am attempting to isolate vocals from a song...vocals that I want to use for a separate project.
In a tutorial, I'm told to go to Effects, and then click on "Vocal Remover."
However, I don't have that option under Effects.
I'm using a MacBook Pro with Sierra...and just downloaded the latest Audacity.
Is the "Vocal Remover" option no longer available? I'm watching a tutorial from 2013.
If not, is there an Effect that's similar to the Vocal Remover option on the latest Audacity?
I sincerely appreciate any help you can provide.
Thank you!
~Michael
Michael221
Re: Vocal Remover Isolation Effect Not Available?
Permanent link to this post Posted by steve » Sat Oct 21, 2017 3:06 pm
Michael221 wrote:In a tutorial, I'm told to go to Effects, and then click on "Vocal Remover."
Sounds like you are trying to follow an old tutorial for an old version of Audacity.
Michael221 wrote:and just downloaded the latest Audacity.
Unless you tell us the actual version number (from Audacity > About Audacity), we don't know which version you mean because we don't know where you downloaded from. Even on the official Audacity website we have "nightly builds" and "beta" versions in addition to the current release version.
Michael221 wrote:Is the "Vocal Remover" option no longer available?
The Vocal Remover effect is still available, but it has been superseded by a new "Vocal Reduction and Isolation" effect (http://manual.audacityteam.org/man/voca ... ation.html)
Michael221 wrote: I'm watching a tutorial from 2013.
That's ancient ;)
Try the manual: http://manual.audacityteam.org/man/tuto ... ation.html
Permanent link to this post Posted by billw58 » Sat Oct 21, 2017 3:06 pm
There are two effects that deal with isolating or removing centre-panned vocals.
There is Vocal Reduction and Isolation effect.
There is a tutorial on using the above effect.
There is also Vocal Remover but this is considered a "legacy" effect, since the "Vocal Reduction and Isolation" effect does everything it does, and more.
Finally, note carefully the disclaimer at the top of the tutorial page:
This page describes techniques which, on some stereo tracks, may allow you to remove or isolate vocals (or other parts of a recording) from the rest. There is no universal, reliable way of doing this without having the original multi-track recordings.
-- Bill
Reason: typo
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 9 guests
