Audacity Equalization Error and Crash
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by sarahmacl » Fri Oct 20, 2017 4:56 am
Every time I select audio and go Effect>Equalizer, i receive this error:
Error Loading EQ Curves from file:
/Users/sarahmaclellan/Library/Application Support/audacity/EQCurves.xml
Error message says:
Error: no element found at line 1
I have tried locating the EQcurve.xml file, however, I cannot locate it. I even tried reinstalling Audacity.
Using MAC Sierra v. 10.12.6
Any suggestions on a fix for this? I use the equalizer a lot and have never had this issue before.
Have attached the error report.
ErrorReport.xml
(368.96 KiB) Downloaded 6 times
sarahmacl
Re: Audacity Equalization Error and Crash
Permanent link to this post Posted by billw58 » Fri Oct 20, 2017 11:59 pm
In the Finder, click on the "Go" menu, then select "Go to folder..."
In the dialog, type: ~/sarahmaclellan/Library/Application Support/audacity then click OK.
Have you used the "Save / Manage Curves" function to save some named, custom curves? If not, trash the "EQCurves.xml" file you'll find there.
If you have some custom curves you want to save, do this:
- open EQCurves.xml in TextEdit
- copy and paste the contents of that file to a message here: I'll have a look at it and see if anything can be salvaged.
-- Bill
billw58
Permanent link to this post Posted by sarahmacl » Wed Oct 25, 2017 6:30 pm
So I think that's the problem. When I went to uninstall Audacity and reinstall, I think I stupidly deleted that folder :(. Any ideas on how to get that back?
billw58 wrote:In the Finder, click on the "Go" menu, then select "Go to folder..."
-- Bill
sarahmacl
Permanent link to this post Posted by billw58 » Wed Oct 25, 2017 11:33 pm
If you deleted the audacity folder inside Application Support, you have effectively reset Audacity.
If you have run Audacity, it will create that audacity folder, so you should still be able to get to it using the Go command as I described.
If you are still getting the crash when using the Equalization effect then it is some other issue than a bad EQCurves.xml file.
-- Bill
billw58
Permanent link to this post Posted by sarahmacl » Thu Oct 26, 2017 3:34 am
Have found the Application Support folder, however, inside it all i see is the libraries folder. There wasn't an EQCruves.xml there, even before i re-installed.
I did re-download the default one through this link http://wiki.audacityteam.org/wiki/EQCurvesDownload, but the issue remains.
Here's the text from that file:
Code: Select all
<equalizationeffect>
   <curve name="AM Radio">
      <point f="20.000000000000" d="-63.670000000000"/>
      <point f="31.000000000000" d="-33.219000000000"/>
      <point f="50.000000000000" d="-3.010000000000"/>
      <point f="63.000000000000" d="-0.106000000000"/>
      <point f="100.000000000000" d="0.000000000000"/>
      <point f="2500.000000000000" d="0.000000000000"/>
      <point f="4000.000000000000" d="-0.614000000000"/>
      <point f="5000.000000000000" d="-8.059000000000"/>
      <point f="8000.000000000000" d="-39.981000000000"/>
      <point f="20000.000000000000" d="-103.651000000000"/>
      <point f="48000.000000000000" d="-164.485000000000"/>
   </curve>
   <curve name="Telephone">
      <point f="20.000000000000" d="-94.087000000000"/>
      <point f="200.000000000000" d="-14.254000000000"/>
      <point f="250.000000000000" d="-7.243000000000"/>
      <point f="315.000000000000" d="-2.245000000000"/>
      <point f="400.000000000000" d="-0.414000000000"/>
      <point f="500.000000000000" d="0.000000000000"/>
      <point f="3150.000000000000" d="-0.874000000000"/>
      <point f="4000.000000000000" d="-3.992000000000"/>
      <point f="5000.000000000000" d="-9.993000000000"/>
      <point f="48000.000000000000" d="-88.117000000000"/>
   </curve>
   <curve name="Walkie-talkie">
      <point f="100.000000000000" d="-120.000000000000"/>
      <point f="101.000000000000" d="0.000000000000"/>
      <point f="2000.000000000000" d="0.000000000000"/>
      <point f="2001.000000000000" d="-120.000000000000"/>
   </curve>
   <curve name="100Hz Rumble">
      <point f="20.000000000000" d="-80.000000000000"/>
      <point f="49.237316986327" d="-33.107692718506"/>
      <point f="54.196034330446" d="-29.553844451904"/>
      <point f="88.033573501041" d="-6.923076629639"/>
      <point f="95.871851182279" d="-4.523078918457"/>
      <point f="108.957037410504" d="-1.938461303711"/>
      <point f="123.828171198057" d="-0.738462448120"/>
      <point f="149.228077614658" d="-0.092308044434"/>
   </curve>
   <curve name="RIAA">
      <point f="20.000000000000" d="19.274000000000"/>
      <point f="25.000000000000" d="18.954000000000"/>
      <point f="31.000000000000" d="18.516000000000"/>
      <point f="40.000000000000" d="17.792000000000"/>
      <point f="50.000000000000" d="16.946000000000"/>
      <point f="63.000000000000" d="15.852000000000"/>
      <point f="80.000000000000" d="14.506000000000"/>
      <point f="100.000000000000" d="13.088000000000"/>
      <point f="125.000000000000" d="11.563000000000"/>
      <point f="160.000000000000" d="9.809000000000"/>
      <point f="200.000000000000" d="8.219000000000"/>
      <point f="250.000000000000" d="6.677000000000"/>
      <point f="315.000000000000" d="5.179000000000"/>
      <point f="400.000000000000" d="3.784000000000"/>
      <point f="500.000000000000" d="2.648000000000"/>
      <point f="630.000000000000" d="1.642000000000"/>
      <point f="800.000000000000" d="0.751000000000"/>
      <point f="1000.000000000000" d="0.000000000000"/>
      <point f="1250.000000000000" d="-0.744000000000"/>
      <point f="1600.000000000000" d="-1.643000000000"/>
      <point f="2000.000000000000" d="-2.589000000000"/>
      <point f="2500.000000000000" d="-3.700000000000"/>
      <point f="3150.000000000000" d="-5.038000000000"/>
      <point f="4000.000000000000" d="-6.605000000000"/>
      <point f="5000.000000000000" d="-8.210000000000"/>
      <point f="6300.000000000000" d="-9.980000000000"/>
      <point f="8000.000000000000" d="-11.894000000000"/>
      <point f="10000.000000000000" d="-13.734000000000"/>
      <point f="12500.000000000000" d="-15.609000000000"/>
      <point f="16000.000000000000" d="-17.708000000000"/>
      <point f="20000.000000000000" d="-19.620000000000"/>
      <point f="25000.000000000000" d="-21.542000000000"/>
      <point f="48000.000000000000" d="-27.187000000000"/>
   </curve>
   <curve name="Bass Boost">
      <point f="100.000000000000" d="9.000000000000"/>
   </curve>
   <curve name="Bass Cut">
      <point f="150.000000000000" d="-50.000000000000"/>
      <point f="300.000000000000" d="0.000000000000"/>
   </curve>
   <curve name="Treble Boost">
      <point f="4000.000000000000" d="0.000000000000"/>
      <point f="5000.000000000000" d="9.000000000000"/>
   </curve>
   <curve name="Treble Cut">
      <point f="6000.000000000000" d="0.000000000000"/>
      <point f="10000.000000000000" d="-110.000000000000"/>
   </curve>
   <curve name="Low rolloff for speech">
      <point f="50.0" d="-120.0"/>
      <point f="60.0" d="-50.0"/>
      <point f="65.0" d="-24.0"/>
      <point f="70.0" d="-12.0"/>
      <point f="80.0" d="-4.0"/>
      <point f="90.0" d="-1.0"/>
      <point f="100.0" d="0.0"/>
   </curve>
   <curve name="unnamed"/>
</equalizationeffect>
Reason: code tags added for readability
sarahmacl
Permanent link to this post Posted by billw58 » Thu Oct 26, 2017 1:30 pm
sarahmacl wrote:Have found the Application Support folder, however, inside it all i see is the libraries folder.
That's probably the wrong Application Support folder. There are two.
One is at /Library/Application Support/audacity
the other is at ~/Library/Application Support/audacity.
Note the "~" character in the second one. That is the place you want to look.
Also, there should be a "libs" folder inside /Library/Application Support/audacity, not a folder named "libraries".
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
