Can I restore my project, if I have only _data dir?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by Zhanna » Thu Oct 19, 2017 7:18 pm
Hi!
Can I restore my project, if I haven't .aup file (I accidentally delet it), but have project_data dir?
Zhanna
Re: Can I restore my project, if I have only _data dir?
Permanent link to this post Posted by kozikowski » Thu Oct 19, 2017 7:34 pm
Did you empty your Trash Can? Did you close Audacity? You should be thinking of what to do if the show never comes back.
Is it an edited show or production? If it is, that's the end of the world. The AUP file is a list of all your edits, filters, corrections and effects. Without that, you have a _DATA directory of trash.
If the show was a straight, plain, non-edited Mono recording, you might be able to recover it manually, but I'm not sure the tools work on a Mac. Scroll down.
http://manual.audacityteam.org/man/recovery.html
If you have a simple stereo recording with no edits, you may get the show back, but Left and Right sound may reverse at random.
We recommend File > Export a WAV (Microsoft) backup sound file of important work.
Permanent link to this post Posted by Zhanna » Fri Oct 20, 2017 7:51 pm
Thanks a lot!)
Zhanna
Permanent link to this post Posted by kozikowski » Fri Oct 20, 2017 8:06 pm
You hit one of the disasters where recovery is not good.
Return to Mac OS X
Who is online
Users browsing this forum: Google [Bot] and 2 guests
