Adjusting EQ on the timeline
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by antarapigeon » Thu Oct 19, 2017 6:18 pm
Hi guys!
I have a rather simple need, and i've been looking my eyes out to find how to do it. In a piece of software that does way more advanced stuff, I cannot believe this is impossible.
I want to modify the amount of a frequency (just lo or mid or hi) gradually (like a fade, but just for a particular frequency).
What you do in other software (say, Ableton) - you switch on a control line on the waveform for, say, "low" - make your own points on it and drag them up or down to manually create a curve you need.
Similar how you would use envelope tool in Audacity to adjust your track volume.
I can imagine something like that can be achieved via Spectogram, but maan, that sounds way too complicated for such a simple task.
Hope someone can shed a light!
And happy crispy fall to you all :)
antarapigeon
Re: Adjusting EQ on the timeline
Permanent link to this post Posted by steve » Thu Oct 19, 2017 6:44 pm
Probably the easiest way is:
1) Duplicate the track (command + D)
2) Apply EQ to the duplicate
3) Crossfade the two tracks (http://manual.audacityteam.org/man/cros ... racks.html)
Permanent link to this post Posted by antarapigeon » Thu Oct 19, 2017 7:19 pm
So I cannot make a manual "zigzag" of the desired frequency if i want to? I thought it's something that many people would need? I guess not, then :D
antarapigeon
Permanent link to this post Posted by kozikowski » Thu Oct 19, 2017 7:39 pm
Audacity doesn't do much in real time. You can create the tracks as above and zig zag back and forth in post production with the Envelope Tool.
http://manual.audacityteam.org/man/envelope_tool.html
Permanent link to this post Posted by antarapigeon » Thu Oct 19, 2017 7:44 pm
Thank you so much for such fast answers!
And thank you for the big work developing all this!
antarapigeon
Permanent link to this post Posted by steve » Thu Oct 19, 2017 7:44 pm
antarapigeon wrote:So I cannot make a manual "zigzag" of the desired frequency if i want to?
Yes you can, but that's not what you asked.
By "Zigzag" I presume that you mean something like this "High Pass Filter (LFO)" effect:
http://wiki.audacityteam.org/wiki/Nyqui ... _.28LFO.29
Permanent link to this post Posted by antarapigeon » Thu Oct 19, 2017 7:57 pm
Well high pass filter will still apply itself to the selected part of the track in a constant level.
What I want to do is, for example, use zero % bass for the first 10 seconds of the track, then increase it from zero to 50% over the course of the next 5 seconds, then keep it at 50%, then reduce again, and so on. I don't need to listen real-time to what i'm doing, just be able to see the visual representation on the timeline somehow. But I understand, this is not a feature, no problems!
antarapigeon
Permanent link to this post Posted by steve » Thu Oct 19, 2017 9:16 pm
You could use the envelope tool *http://manual.audacityteam.org/man/envelope_tool.html) to control how much of each track:
Permanent link to this post Posted by antarapigeon » Thu Oct 19, 2017 10:56 pm
thanks for the hack! :)
antarapigeon
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 8 guests
