Chain ExportMP3 isn't working
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: Chain ExportMP3 isn't working
Permanent link to this post Posted by MacDork » Fri Oct 13, 2017 12:17 pm
Turns out it was ClipFix =/
Equalizer works great, but ClipFix is the one I really wanted, so that's a bummer. Are there any general tips/tricks for a crashing effect?
MacDork
Permanent link to this post Posted by steve » Fri Oct 13, 2017 12:22 pm
How long is the track that you are trying to process?
Permanent link to this post Posted by MacDork » Fri Oct 13, 2017 3:43 pm
About 30 minutes
MacDork
Permanent link to this post Posted by steve » Fri Oct 13, 2017 4:14 pm
There was a problem with ClipFix that caused it to fail on 'long' tracks. The problem would occur in tracks that are about 30 minutes or more in length.
The problem has been fixed in the next release of Audacity.
Permanent link to this post Posted by MacDork » Fri Oct 13, 2017 5:26 pm
Sweet! Thanks!
MacDork
Permanent link to this post Posted by billw58 » Fri Oct 13, 2017 8:57 pm
I still think you should name the Equalization curve you're using in the chain. The shape of the "untitled" curve will change if you use the Equalization effect outside of the chain and make any changes to the curve / sliders.
-- Bill
billw58
Permanent link to this post Posted by MacDork » Mon Oct 16, 2017 11:43 am
Ooh. Good call. Thanks, Bill.
MacDork
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
