Audacity 2.1.3 plug-in folder
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by gliran » Wed Oct 11, 2017 2:30 pm
Hi,
I have installed Audacity 2.1.3 and then tried to install a Nyquist plug-in but the installation dod not create a plug-in folder.
Thoughts?
GL
gliran
Re: Audacity 2.1.3 plug-in folder
Permanent link to this post Posted by steve » Wed Oct 11, 2017 2:36 pm
Perhaps you're not looking in the right place:
~/Library/Application Support/audacity/Plug-Ins
("~/" means your home folder)
Permanent link to this post Posted by gliran » Wed Oct 11, 2017 2:56 pm
Thanks for the advise but I am looking at the right place. There is no /audacity/Plug-Ins folders under Application Support folder.
Other thoughts?
GL
gliran
Permanent link to this post Posted by gliran » Wed Oct 11, 2017 3:29 pm
gliran wrote:Thanks for the advise but I am looking at the right place. There is no /audacity/Plug-Ins folders under Application Support folder.
I am running on MacOS Hi Sierra
Other thoughts?
GL
gliran
Permanent link to this post Posted by steve » Wed Oct 11, 2017 3:30 pm
Where exactly are you looking?
"/Library" is a folder in the root directory.
"~/Library" is a folder in your home directory
"Application Support" is meaningless without giving a fully qualified path.
Permanent link to this post Posted by gliran » Wed Oct 11, 2017 4:51 pm
Hi Steve,
I know and no plug-ins folder or files are created when installing the app on Hi Sierra. Apparently they have problems with this OS.
I am in the right place, under Home/library/Application support/.... Audacity folder and subfolders are not created.
I tried to manually create them and drag in the Nyquist band stop filter plugin for Audacity at no avail, it will not recognize it and as a matter of fact, in the Audacity app most of the effect plug-ins are grey.
I will contact the developers.
Thanks
Gil
gliran
Permanent link to this post Posted by steve » Wed Oct 11, 2017 5:20 pm
gliran wrote:Apparently they have problems with this OS.
Who are "they"?
gliran wrote:I will contact the developers.
This (the the forum) is the only user support channel.
How did you install Audacity 2.1.3?
Return to Mac OS X
Who is online
Users browsing this forum: billw58 and 6 guests
