Need help with Audacity 2.1.3 OS X Yosemite
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
Re: Need help with Audacity 2.1.3 OS X Yosemite
Permanent link to this post Posted by billw58 » Wed Oct 18, 2017 2:02 am
Since we don't know what caused your problem it's kind of hard to suggest a way to prevent it!
That said, I like to do File > Save Project As before I begin recording. That way all recorded audio goes into the project directory instead of the temp directory. Subsequent saves are super-fast. You do save at each break in recording, don't you? ;)
-- Bill
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
