audio cuts in and out...
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by thefootballfanatic » Sat Oct 07, 2017 2:31 am
Twice now I have been recording an hour long podcast episode with my friend, but when I go back to edit the episode I find half the audio is missing because it cuts in and out so much. Why is this? What is causing it? I can't figure out why this would be, I have no other programs running so it isn't the system memory.
thefootballfanatic
Re: audio cuts in and out...
Permanent link to this post Posted by billw58 » Sat Oct 07, 2017 3:09 am
We don't know exactly what causes it, but we have a workaround.
Go to Audacity > Preferences, then the Recording section. Set "Audio to buffer" as low as you can consistent with still getting a good recording. Try 20 milliseconds.
By the way, what interface are you using? This problem usually shows up when using an external USB audio converter.
-- Bill
billw58
Permanent link to this post Posted by steve » Sat Oct 07, 2017 11:48 am
Probably also a good idea to set the system sample rate (in "Applications > Utilities > Audio MIDI Setup") the same as the sample rate that you wish to use in Audacity.
To set the default sample rate in Audacity, "Preferences > Quality".
Permanent link to this post Posted by thefootballfanatic » Sat Oct 07, 2017 1:40 pm
I already had it set to 50, but I guess I'll lower it to 20.
I'm using a FocusRite Scarlett 2i2.
What should the sample rate be? I'm new to audio, I don't really know what those settings should be.
thefootballfanatic
Permanent link to this post Posted by billw58 » Sat Oct 07, 2017 2:29 pm
Set the sample rate to 44100 and the sample format to 16-bit integer, both in the Focusrite (through Audio-MIDI Setup - the information on this page might help) and in Audacity (at Quality Preferences).
-- Bill
billw58
Permanent link to this post Posted by thefootballfanatic » Sat Oct 07, 2017 11:44 pm
I have 44100 and 16-bit in the Audacity settings now. Can't figure out the FocusRite one though... it says 24bit and it is greyed out, so it doesn't seem like I can change it.
thefootballfanatic
Permanent link to this post Posted by billw58 » Sun Oct 08, 2017 10:51 pm
Which version of the 2i2 do you have? Did it come with a driver installer?
What do you see in Audio-MIDI Setup when you select the 2i2? A screen shot may help.
This page may help.
-- Bill
billw58
Permanent link to this post Posted by audacityhelpme123 » Tue Oct 10, 2017 2:14 pm
Hey I am using audacity 2.1.3 and I am also having this problem. I attempted changing the project rate too and this still occurs. It's really frustrating as this used to not happen on my old laptop which had less specs and I used a really cheap microphone.
audacityhelpme123
Operating System: Windows 7
Permanent link to this post Posted by billw58 » Tue Oct 10, 2017 5:42 pm
audacityhelpme123 wrote:Hey I am using audacity 2.1.3 and I am also having this problem. I attempted changing the project rate too and this still occurs. It's really frustrating as this used to not happen on my old laptop which had less specs and I used a really cheap microphone.
Try changing the Audio to Buffer setting in Recording Preferences to 20.
-- Bill
billw58
Permanent link to this post Posted by billw58 » Wed Oct 11, 2017 12:58 am
As it turns out, there's an FAQ for that.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
