Audacity Crashes (screenshots included)
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by b3790 » Mon Oct 02, 2017 5:33 pm
Screen Shot 2017-10-02 at 1.22.09 PM.png (863.34 KiB) Viewed 184 times
Screen Shot 2017-10-02 at 1.22.19 PM.png (747.47 KiB) Viewed 184 times
Hi, whenever I import an already recorded file into audacity and try to equalize it, it crashes. Here are some screenshots that I took after the most recent one. Any help you could provide would be greatly appreciated as I am unsure what the problem is... Information on my MAc OS etc is in the attached screenshots.
Thanks
Screen Shot 2017-10-02 at 1.29.03 PM.png (725.56 KiB) Viewed 184 times
b3790
Re: Audacity Crashes (screenshots included)
Permanent link to this post Posted by billw58 » Mon Oct 02, 2017 8:28 pm
b3790 wrote:Hi, whenever I import an already recorded file into audacity and try to equalize it, it crashes. Here are some screenshots that I took after the most recent one. Any help you could provide would be greatly appreciated as I am unsure what the problem is... Information on my MAc OS etc is in the attached screenshots.
It appears that the screen shot with the most useful information was cut off. Next time this happens please copy and paste the text from the "Audacity quit unexpectedly" dialog. Not all of it, but from the top, including "Thread 0 Crashed" and the full trace of thread 0. That will help us narrow down the problem.
Also, exactly when does the crash occur? When opening the Equalization effect? When applying an equalization curve? When choosing a curve from the "Select Curve:" dropdown?
The above assumes you mean the Equalization effect when you say "try to equalize it"? Were you doing something other than using the Equalization effect?
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
