Logitech USB H390 headset with Mac 10.12.6 Sierra
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by mailvachu » Sun Oct 01, 2017 1:27 pm
I have Logitech H390 USB headset. I tried using on Macbook Air. using audacity to record some tracks.
Here are the problems:
1. When I select Microphone as Logitech device, it will change to Mono instead of Stereo.
2. When I try recording audio track recorded is hardly audible... very low.
I have tested the same using H340 headset.. it works perfectly fine. Only issue when I use H390 model
Mac OS version : 10.12.6 Sierra
Audacity version : 2.1.3
Can you please suggest a fix for this?
Thank you.
/vachu
mailvachu
Re: Logitech USB H390 headset with Mac 10.12.6 Sierra
Permanent link to this post Posted by kozikowski » Sun Oct 01, 2017 2:36 pm
The H390 has a very aggressive noise-cancelling microphone. That looks like the one I have. I stopped using it because of low volume and ratty voice quality.
But it did cancel room noise. You can use the Audacity tools to boost the volume in post production (Amplify, Normalize) but digital microphones record with fixed volume. The Audacity recording volume control snaps all the way up when you select the microphone, right?
Right. It's a single microphone and naturally records mono. Some microphone systems will mount either stereo or mono, but some won't. You can make "stereo" later by duplicating the track with Command-D and then use the drop-down menu to the left of the top track > Make Stereo Track.
The H340 is marketed for higher quality voice performances.
Permanent link to this post Posted by mailvachu » Tue Oct 03, 2017 4:30 pm
Thanks Koz.
Your observations are right too... H340 is older model which has all the supports like stereo recording as well as sound amplification.
Why don't we extend the same enable the same for H390 also in Audacity?
Can't be fixed in Audacity at all??
Thank you.
/vachu
mailvachu
Permanent link to this post Posted by mailvachu » Tue Oct 03, 2017 4:37 pm
Hi Koz,
One more thing which I could not get :
What is command-D ? How to invoke that? In my track, "Make Stereo Track" is always disabled.
Thank you.
/vachu
mailvachu
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 9 guests
