Audio cutting out
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Audio cutting out
Permanent link to this post Posted by mellowmuffle330 » Sat Sep 30, 2017 9:14 pm
Audacity 2.1.3
Mac OSX El capitan
.dmg
Hello,
While recording a vinyl record today everything sounded great while recording, however, when I listened back the audio file skipped tiny sections of the music almost as if the record had skipped, but it hadn't. What would cause this? I recently recorded something in 24bit 48khz and it came out fine, but today when this issue occurred I had bumped it up to 24bit 96khz. I am using a project USB v phone preamp that process the signal from the turntable into my laptop. Could this be a result of the preamp, say if it wasn't rated to process information of such high quality?
Thanks for your help!
mellowmuffle330
Re: Audio cutting out
Permanent link to this post Posted by billw58 » Sat Sep 30, 2017 9:43 pm
Given the frequency response and noise floor of vinyl, 16-bit 44100 Hz is all you need.
Given that the problems started when you tried 96000 Hz, I suspect that is the problem. Go back to what works.
-- Bill
billw58
Permanent link to this post Posted by mellowmuffle330 » Sat Sep 30, 2017 10:13 pm
Thankyou!
mellowmuffle330
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 9 guests
