Is Audacity Compatible with MacOS High Sierra?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by MLMeraz » Wed Sep 27, 2017 6:13 pm
I'm currently running the latest version of Audacity on my MacBook Pro which is running Mac OS Sierra. Audacity has been working fine for my needs. But I'm interested in upgrading my Mac to the newly released High Sierra. I'm wondering if Audacity has any known issues with High Sierra that would prevent me from upgrading? My audio editing needs aren't complex but I do use the software a lot. So, I don't want to upgrade to the new MacOS if Audacity will break.
Thanks in advance for any info. I searched but couldn't find much info. I'm guessing others might be wondering the same thing.
Mike
MLMeraz
Re: Is Audacity Compatible with MacOS High Sierra?
Permanent link to this post Posted by steve » Wed Sep 27, 2017 6:25 pm
Apple recommend that you perform a full back-up before updating to high sierra.
As high sierra has only been out for a couple of days, there's not much information about real-world performance of high sierra.
Permanent link to this post Posted by MLMeraz » Wed Sep 27, 2017 10:36 pm
Thanks, Steve. Yes, I’m familiar with the upgrade process and backing up prior. I’m just hoping to avoid the hassle of reverting back to Sierra if Audacity functionality breaks. I’ve researched all my primary applications and know that all of them will work with High Sierra. It’s just Audacity that I can’t find any info on.
MLMeraz
Permanent link to this post Posted by ymichaud » Thu Sep 28, 2017 12:14 pm
Here's my experience with High Sierra 10.13:
I've notice a delay (roughly half a second) when listening to a track, but worse, recording using an application to redirect the internal sound to Audacity, Soundflower, give a choppy sound while recording. This is only cosmetic as the recording result is perfect. I thought the problem came from Soundflower, so I replace it with another application doing the same, iShowU Audio Capture, who give the same choppy sound while recording which make me believe the problem come from Audacity.
I've decided to downgrade to MacOS 10.12
ymichaud
Permanent link to this post Posted by tmtomh » Sat Sep 30, 2017 1:59 am
For what it's worth, I upgraded my MacBook Air to High Sierra a few days ago, without even considering Audacity compatibility. I did this because my Air is my secondary Audacity machine - my primary audio-editing Mac remains on Sierra for now.
Anyway, I can't comment on recording with Audacity, but in terms of the usual editing stuff - loading up tracks, applying filters, zooming in and out, selecting audio, exporting, etc. - Audacity 2.1.3 works perfectly for me in High Sierra, just as it did under Sierra.
tmtomh
Permanent link to this post Posted by waxcylinder » Sat Sep 30, 2017 11:26 am
tmtomh wrote:For what it's worth, I upgraded my MacBook Air to High Sierra a few days ago, without even considering Audacity compatibility. I did this because my Air is my secondary Audacity machine - my primary audio-editing Mac remains on Sierra for now.
Thanks for that reassuring post tmtomh - much appreciated :)
waxcylinder
Permanent link to this post Posted by waxcylinder » Sat Sep 30, 2017 1:10 pm
Well, emboldened by tmtomh's post, I set about upgrading my Sierra 10.12.6 Sierra Macbook Pro (used for Audacity QA testing) to 10.13 High Sierra.
I have successfully run both the released 2.1.3 released version of Audacity and the latest 2.2.0 alpha nightly - both run just fine.
Testing included recording, both from the onboard mic on the Mac - and recording with my external USB soundcard (Edirol UA-1EX) and the new MIDI playback that comes with 2.2.0
So yes, I'm pretty confident that Audacity runs just fine on High Sierra.
waxcylinder
Permanent link to this post Posted by MLMeraz » Sun Oct 01, 2017 6:30 pm
Thanks, so much. As "editing" is my primary activity right now, this is particularly helpful.
MLMeraz
Permanent link to this post Posted by kozikowski » Mon Oct 02, 2017 12:32 am
Many of the mainstream tech writers are saying the shift from Sierra to High Sierra was not particularly serious, and they weren't expecting much thunder and lightning certainly compared to some of the other upgrades.
Lots of background tweaks and deep system changes.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
