I export 48khz 24 bit audio file?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by [email protected] » Thu Sep 21, 2017 4:13 pm
I want to record and export in 48kHZ 24bit. I set this rate in the setting, but it is not available in the dropdown menu at exporting time. I have MAC ElCapitan
[email protected]
Re: I export 48khz 24 bit audio file?
Permanent link to this post Posted by billw58 » Thu Sep 21, 2017 4:36 pm
Select Custom FFmpeg Export in the "File Type" dropdown of the Export Audio dialog. Then click "Open custom FFmpeg export options". In the intimidating dialog that appears, in the "Formats" list select "wav" and in the "Codecs" list select "pcm24_sle.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
