Audacity 2.1.3 won't open saved projects with Mac OS 10.12
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by wetzel35 » Wed Sep 20, 2017 6:32 pm
Hi. I am working with students on a project and I am seeing the same issue many times. Here it is:
ISSUE: A titled, "saved as" .aup with all of its reference files in tact and unmoved, will not open after being saved and closed. I establish a project folder; save and title the project to said folder, import raw audio from the same folder; save; close; and then try to reopen, but the project will not open (if I saved the project file as TEST1, when I try to reopen Audacity simply ignores the project and opens a new blank project (titled Audacity) with no error message -- as if TEST1 doesn't exist.
I have seen this on three occasions today, on 3 different machines, all using Sierra 10.12.
Can anyone advise!?
Many thanks
wetzel35
Re: Audacity 2.1.3 won't open saved projects with Mac OS 10.
Permanent link to this post Posted by kozikowski » Thu Sep 21, 2017 3:20 am
I read that four times and I still can't visualize what you're doing.
Make a show or open an existing one. Save As a different simple show name on your home machine desktop. Close Audacity. Double click the AUP file on the desktop. What happens?
Permanent link to this post Posted by wetzel35 » Thu Sep 21, 2017 5:36 pm
I am working on various student computers, all of which are 10.12 Sierra.
I create a project (save as), import audio, save, close. Reopen and Audacity simply opens a blank project which is not my project (doesn't have my project title), opens as "Audacity" (this is the title at the top of Audacity interface).
Crazily, if I duplicate the project file and open THAT project (the duplicated project), it will open with the imported audio.
I have uninstalled Audacity and reinstalled and still doesn't work.
Does the above make sense? Trying to install and use 2.1.3.
wetzel35
Permanent link to this post Posted by wetzel35 » Thu Sep 21, 2017 6:02 pm
Hi Actually! -- Beta Audacity 2.2 fixes the problem.
wetzel35
Permanent link to this post Posted by billw58 » Mon Sep 25, 2017 7:37 pm
wetzel35 wrote:Hi Actually! -- Beta Audacity 2.2 fixes the problem.
That makes sense, as the problem you describe (double-clicking a AUP file opens an empty project window) is a known bug in 2.1.3 that is fixed in 2.2.0.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
