I can move selection between tracks - but how then to split?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by EricMC » Fri Sep 08, 2017 7:32 am
I discovered that I can use the up and down arrows to move between tracks, apparently keeping the selection point at exactly the same place in each.
I would love then to be able to hit Cmd+I in order to split the second track at exactly the same point.
But I find that Audacity does not treat it like a selection point: at any rate, I cannot use Cmd+I until I actively click in that track — and, more often than not, when I click in the second track, the selection will not be at exactly the same place as in the track above (or below).
Any ideas whether I can tell Audacity to select the same point in a different track without using the mouse?
EricMC
Re: I can move selection between tracks - but how then to sp
Permanent link to this post Posted by steve » Fri Sep 08, 2017 9:09 am
The up / down keys move "track focus" (indicated by yellow border to the track).
To toggle the selection on/off for the track that has focus, press "Enter".
Cmd + i , like most other commands, operates on the selected audio.
Permanent link to this post Posted by EricMC » Thu Nov 02, 2017 9:54 am
Works a treat.
Thanks, Steve.
EricMC
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 10 guests
