the recording is playing backwards
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by patnich » Fri Aug 11, 2017 9:08 pm
Not sure how I did that. Would like to change it back , how do I do that? Is it in the manual?
macos sierra, new version 2.1.3 downloaded
thx, pat
patnich
Re: the recording is playing backwards
Permanent link to this post Posted by patnich » Fri Aug 11, 2017 9:11 pm
I fixed it. thx, pat
patnich
Permanent link to this post Posted by Trebor » Fri Aug 11, 2017 11:04 pm
For those with the same problem : you've accidentally engaged scrubbing.
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
