Nyquist Returned the Value: 1
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by tkshelton » Thu Aug 10, 2017 3:36 am
New Interested User - Audacity 2.1.3 installed. MacOS Sierra 10.12.6 on iMac. 64GB.
Attempted to utilize multiple effects on multiple mp3 files, such as Low Pass Band filter, High Pass Band Filter, Vocal Reduction and Isolation - Remove Center and Isolate Center and Invert. ALL return a dialog box: "Nyquist Returned the value: 1". None of the desired effects were applied. I have reviewed the forum, FAQ, Tutorial and the Bugslist. I have not been able to understand what this dialog box means. I did select 'debug' from the dialog box and it looked like there was an unbounded condition.
Please advise
NOTE: I can split the stereo file and apply the invert effect.
tkshelton
Re: Nyquist Returned the Value: 1
Permanent link to this post Posted by steve » Thu Aug 10, 2017 10:37 am
tkshelton wrote:Attempted to utilize multiple effects on multiple mp3 files, such as Low Pass Band filter, High Pass Band Filter, Vocal Reduction and Isolation - Remove Center and Isolate Center and Invert. ALL return a dialog box: "Nyquist Returned the value: 1".
Try running each of the effects manually, with the settings that you are using in the Chain. Which of the effects fails?
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
