Moving selected sound files horizontally
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by cardo » Wed Aug 09, 2017 6:40 am
How does one move a selected or highlighted sound file horizontally? In other words, is there a way to grab a drop a sound file without relying on the cursor or grid? Thanks.
cardo
Re: Moving selected sound files horizontally
Permanent link to this post Posted by steve » Wed Aug 09, 2017 8:05 am
If there is empty space to move it into, you can grab and slide audio clips with the Time Shift tool.
Another option is cut and paste (Shortcuts, Command + X, Command + V).
Permanent link to this post Posted by cardo » Thu Aug 10, 2017 2:33 pm
Thanks Steve..
cardo
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
