Equalization effect causes Audacity to crash
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by TonyP » Sat Aug 05, 2017 6:53 pm
My OS is 10.10.5 and have Audacity 2.1.3 installed. I am using a MacBook Pro Retina, 15 inch, Mid 2015.
I am just beginning to relearn Audacity and have run into a issue. With my waveform open in a new project Audacity constantly crashes when I go to Effects/Equalization. The crash is immediate without making any sort of change in the settings.
Any help would be greatly appreciated.
TonyP
Operating System: OS X 10.10 Yosemite
Re: Equalization effect causes Audacity to crash
Permanent link to this post Posted by kozikowski » Sat Aug 05, 2017 7:08 pm
Close and Open a fresh Audacity. Generate about a ten seconds of any noise. Does Effect > Equalization still crash?
Permanent link to this post Posted by TonyP » Sun Aug 06, 2017 12:35 am
Yes it does, I have even quit Audacity and relaunched.
After a relaunch and U try to apply Equalization to a waveform I get the following message in a system pop-up box.
'atop needs to take control of another process for debugging to continue. Type your password to allow this'.
I enter my password and a 'Debug report "Audacity"' is generated. After I cancel the 'Debug report "Audacity"' the application closes.
TonyP
Permanent link to this post Posted by billw58 » Sun Aug 06, 2017 3:55 am
I'm wondering if you have any custom EQ curves left over from a previous install of Audacity. Let's find out.
In the Finder, while holding the option key, click on the Go menu and select Library. In the Library folder open Application Support and then audacity.
Inside the audacity folder there may be two files named "EQBackup.xml" and EQCurves.xml". If they are there, move them to the trash. Then try starting Audacity and using the Equalization effect.
If they are not there, or if Audacity still crashes after trashing them, save the Debug report (it should offer to produce a zip file for you) and attach it to a forum message.
-- Bill
billw58
Permanent link to this post Posted by TonyP » Sun Aug 06, 2017 3:50 pm
Hi Bill,
I did locate one of the files you listed and deleted it. Audacity still crashes when Effects/Equalization is selected. I am not sure how to access the path to the zip file listed in the debug box. The path is:
/var/folders/zc/z44mr1d91hg8ddc2rtpcprn40000gn/T/Audacity_dbgrpt-612-201.
Also I do not see a option for attaching a file in this forum reply section. Under the forum FAQ I see attaching files may be a permission not granted by the administrator of the forum.
TonyP
Permanent link to this post Posted by TonyP » Sun Aug 06, 2017 4:05 pm
I was able to locate the zip file and copy to my desktop. Now the problem is not being able to upload to the forum.
TonyP
Permanent link to this post Posted by kozikowski » Sun Aug 06, 2017 6:59 pm
Right-Click or Control-Click the file > Get INFO.
Does it say something.zip and is the size under 2MB?
Audacity forum restricts both file types and size.
Permanent link to this post Posted by TonyP » Sun Aug 06, 2017 10:07 pm
I have attached the zip file. Its actually quite small.
Audacity_dbgrpt-612-20170806T103337.zip
(8.86 KiB) Downloaded 13 times
TonyP
Permanent link to this post Posted by billw58 » Mon Aug 07, 2017 3:12 am
Sorry, that report is not useful: it does not include the Mac crash log.
When Audacity crashes, do you get a dialog that says Audacity has "quit unexpectedly" and offering to "send a report"? If so, click the "Report" button, copy the first 100 or so lines from that report, then paste them into a message here.
-- Bill
billw58
Permanent link to this post Posted by TonyP » Mon Aug 07, 2017 6:05 pm
I have pasted roughly the first have of the report below. I have also attached the entire report as a zip file incase more info is needed.
Code: Select all
Process:               Audacity [557]
Path:                  /Applications/Audacity.app/Contents/MacOS/Audacity
Identifier:            org.audacityteam.audacity
Version:               2.1.3.0 (2.1.3.0)
Code Type:             X86 (Native)
Parent Process:        ??? [1]
Responsible:           Audacity [557]
User ID:               501
Date/Time:             2017-08-07 12:55:21.405 -0500
OS Version:            Mac OS X 10.10.5 (14F2009)
Report Version:        11
Anonymous UUID:        477C12EA-B121-4BEE-4CE7-EE6394C58451
Time Awake Since Boot: 310 seconds
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGABRT)
Exception Codes:       KERN_INVALID_ADDRESS at 0x000000004032f439
VM Regions Near 0x4032f439:
    __LINKEDIT             0000000015cd2000-0000000015cf1000 [  124K] r--/rwx SM=COW  /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    __TEXT                 000000008fee1000-000000008ff15000 [  208K] r-x/rwx SM=COW  /usr/lib/dyld
Application Specific Information:
abort() called
Pure virtual function called!
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib           0x94ec569a __pthread_kill + 10
1   libsystem_pthread.dylib          0x9aaed634 pthread_kill + 101
2   libsystem_c.dylib                0x94a11de6 abort + 156
3   libc++abi.dylib                  0x906d92f9 abort_message + 169
4   libc++abi.dylib                  0x906fadc0 __cxa_pure_virtual + 26
5   libwx_baseu_release-3.0.0.2.0.dylib   0x01b45223 wxEvtHandler::ProcessEvent(wxEvent&) + 67
6   libwx_baseu_release-3.0.0.2.0.dylib   0x01b45612 wxEvtHandler::SafelyProcessEvent(wxEvent&) + 34
7   libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x015e646b wxWindowBase::HandleWindowEvent(wxEvent&) const + 27
8   libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014e7208 wxWidgetCocoaImpl::DoNotifyFocusEvent(bool, wxWidgetImpl*) + 376
9   libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014e2ac3 wxWidgetCocoaImpl::resignFirstResponder(NSView*, void*) + 419
10  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014e15ec wxOSX_resignFirstResponder(NSView*, objc_selector*) + 44
11  com.apple.AppKit                 0x9382d9e0 -[NSWindow makeFirstResponder:] + 469
12  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014ceb7e -[wxNSWindow makeFirstResponder:] + 62
13  com.apple.AppKit                 0x9376a736 -[NSView(NSInternal) _setHidden:setNeedsDisplay:] + 1724
14  com.apple.AppKit                 0x9376a066 -[NSView _setHidden:] + 49
15  com.apple.AppKit                 0x9376a024 -[NSView setHidden:] + 41
16  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014e49a1 wxWidgetCocoaImpl::SetVisibility(bool) + 49
17  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x01420ff6 wxWindow::Show(bool) + 86
18  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014196dc wxNonOwnedWindow::Show(bool) + 28
19  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x0141bee6 wxTopLevelWindowMac::Destroy() + 70
20  org.audacityteam.audacity        0x00270cb8 std::tr1::_Sp_counted_base_impl<AudacityProject*, Destroyer<AudacityProject>, (__gnu_cxx::_Lock_policy)2>::_M_dispose() + 24
21  org.audacityteam.audacity        0x00248370 std::vector<std::tr1::shared_ptr<AudacityProject>, std::allocator<std::tr1::shared_ptr<AudacityProject> > >::~vector() + 64
22  libsystem_c.dylib                0x94a12b49 __cxa_finalize_ranges + 315
23  libsystem_c.dylib                0x94a12bcf __cxa_finalize + 59
24  libsystem_c.dylib                0x94a12ecc exit + 62
25  org.audacityteam.audacity        0x000077df AudacityApp::OnFatalException() + 31
26  libwx_baseu_release-3.0.0.2.0.dylib   0x01b3d730 wxFatalSignalHandler + 32
27  libsystem_platform.dylib         0x97b8903b _sigtramp + 43
28  ???                              0xffffffff 0 + 4294967295
29  libwx_baseu_release-3.0.0.2.0.dylib   0x01b3d710 wxDoSetEnv(wxString const&, char const*) + 400
30  org.audacityteam.audacity        0x000ae649 EffectEqualization::setCurve(wxString const&) + 473
31  org.audacityteam.audacity        0x000ae187 EffectEqualization::Init() + 999
32  org.audacityteam.audacity        0x00090f56 Effect::DoEffect(wxWindow*, double, TrackList*, TrackFactory*, SelectedRegion*, bool) + 1462
33  org.audacityteam.audacity        0x0043ee5a EffectManager::DoEffect(wxString const&, wxWindow*, double, TrackList*, TrackFactory*, SelectedRegion*, bool) + 90
34  org.audacityteam.audacity        0x0020321a AudacityProject::OnEffect(wxString const&, int) + 586
35  org.audacityteam.audacity        0x00210031 PluginFunctor<AudacityProject>::operator()(int, wxEvent const*) + 49
36  org.audacityteam.audacity        0x0034f689 CommandManager::HandleMenuID(int, CommandFlag, CommandFlag) + 169
37  org.audacityteam.audacity        0x0024ad0c AudacityProject::OnMenu(wxCommandEvent&) + 76
38  libwx_baseu_release-3.0.0.2.0.dylib   0x01a409a7 wxAppConsoleBase::HandleEvent(wxEvtHandler*, void (wxEvtHandler::*)(wxEvent&), wxEvent&) const + 39
39  libwx_baseu_release-3.0.0.2.0.dylib   0x01a409f7 wxAppConsoleBase::CallEventHandler(wxEvtHandler*, wxEventFunctor&, wxEvent&) const + 71
40  libwx_baseu_release-3.0.0.2.0.dylib   0x01b44740 wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 304
41  libwx_baseu_release-3.0.0.2.0.dylib   0x01b4529f wxEvtHandler::ProcessEvent(wxEvent&) + 191
42  libwx_baseu_release-3.0.0.2.0.dylib   0x01b45391 wxEvtHandler::ProcessEventLocally(wxEvent&) + 161
43  libwx_baseu_release-3.0.0.2.0.dylib   0x01b45246 wxEvtHandler::ProcessEvent(wxEvent&) + 102
44  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x015eb193 wxWindowBase::TryAfter(wxEvent&) + 147
45  libwx_baseu_release-3.0.0.2.0.dylib   0x01b452c6 wxEvtHandler::ProcessEvent(wxEvent&) + 230
46  libwx_baseu_release-3.0.0.2.0.dylib   0x01b45612 wxEvtHandler::SafelyProcessEvent(wxEvent&) + 34
47  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x015e646b wxWindowBase::HandleWindowEvent(wxEvent&) const + 27
48  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x015976ab wxMenuBase::SendEvent(int, int) + 171
49  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x0143d060 wxMenu::HandleCommandProcess(wxMenuItem*, wxWindow*) + 112
50  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014ca8ba -[wxNSMenuItem clickedAction:] + 42
51  libobjc.A.dylib                  0x9a900853 -[NSObject performSelector:withObject:] + 70
52  com.apple.AppKit                 0x9397cc1e __36-[NSApplication sendAction:to:from:]_block_invoke + 51
53  libsystem_trace.dylib            0x9360fc03 _os_activity_initiate + 89
54  com.apple.AppKit                 0x9397cb37 -[NSApplication sendAction:to:from:] + 602
55  com.apple.AppKit                 0x9397c7dd -[NSMenuItem _corePerformAction] + 479
56  com.apple.AppKit                 0x9397c4ce -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 162
57  com.apple.AppKit                 0x9397bb4a -[NSMenu _performActionWithHighlightingForItemAtIndex:sendAccessibilityNotification:] + 79
58  com.apple.AppKit                 0x93a4e63b __38-[NSMenu performActionForItemAtIndex:]_block_invoke + 52
59  libsystem_trace.dylib            0x9360fc03 _os_activity_initiate + 89
60  com.apple.AppKit                 0x93a4e5ff -[NSMenu performActionForItemAtIndex:] + 141
61  com.apple.AppKit                 0x93a4e55e -[NSMenu _internalPerformActionForItemAtIndex:] + 45
62  com.apple.AppKit                 0x93a4e529 -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 106
63  com.apple.AppKit                 0x93a4e382 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 120
64  com.apple.AppKit                 0x939634e7 NSSLMMenuEventHandler + 679
65  com.apple.HIToolbox              0x9992e5a4 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
66  com.apple.HIToolbox              0x9976c681 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2291
67  com.apple.HIToolbox              0x9976b65c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 402
68  com.apple.HIToolbox              0x9977ff25 SendEventToEventTarget + 88
69  com.apple.HIToolbox              0x9992e422 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 447
70  com.apple.HIToolbox              0x997f227c SendMenuCommandWithContextAndModifiers + 72
71  com.apple.HIToolbox              0x997f2220 SendMenuItemSelectedEvent + 207
72  com.apple.HIToolbox              0x997f20db FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 145
73  com.apple.HIToolbox              0x99980517 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 775
74  com.apple.HIToolbox              0x997f287b _HandleMenuSelection2 + 512
75  com.apple.HIToolbox              0x997f2665 _HandleMenuSelection + 55
76  com.apple.AppKit                 0x93874c26 _NSHandleCarbonMenuEvent + 359
77  com.apple.AppKit                 0x937a3f09 _DPSNextEvent + 1710
78  com.apple.AppKit                 0x937a31e5 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 350
79  com.apple.AppKit                 0x93797b9c -[NSApplication run] + 907
80  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x014c38e8 wxGUIEventLoop::OSXDoRun() + 120
81  libwx_baseu_release-3.0.0.2.0.dylib   0x01b22d2f wxCFEventLoop::DoRun() + 47
82  libwx_baseu_release-3.0.0.2.0.dylib   0x01a70639 wxEventLoopBase::Run() + 89
83  libwx_baseu_release-3.0.0.2.0.dylib   0x01a401a5 wxAppConsoleBase::MainLoop() + 117
84  libwx_osx_cocoau_release_core-3.0.0.2.0.dylib   0x0145ad5e wxApp::OnRun() + 30
85  libwx_baseu_release-3.0.0.2.0.dylib   0x01aab4be wxEntry(int&, wchar_t**) + 78
86  libwx_baseu_release-3.0.0.2.0.dylib   0x01aab602 wxEntry(int&, char**) + 50
87  org.audacityteam.audacity        0x0000537b main + 155
88  org.audacityteam.audacity        0x00002a05 start + 53
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib           0x94ec68ce kevent64 + 10
1   libdispatch.dylib                0x94c78ce3 _dispatch_mgr_invoke + 245
2   libdispatch.dylib                0x94c788c6 _dispatch_mgr_thread + 52
Thread 2:
0   libsystem_kernel.dylib           0x94ebf9ce mach_msg_trap + 10
1   libsystem_kernel.dylib           0x94ebea70 mach_msg + 68
2   com.apple.CoreFoundation         0x91a08ef6 __CFRunLoopServiceMachPort + 214
3   com.apple.CoreFoundation         0x91a08309 __CFRunLoopRun + 1529
4   com.apple.CoreFoundation         0x91a07aa6 CFRunLoopRunSpecific + 390
5   com.apple.CoreFoundation         0x91a0790b CFRunLoopRunInMode + 123
6   com.apple.AppKit                 0x938732d0 _NSEventThread + 283
7   libsystem_pthread.dylib          0x9aaebc25 _pthread_body + 138
8   libsystem_pthread.dylib          0x9aaebb9b _pthread_start + 162
9   libsystem_pthread.dylib          0x9aae8e32 thread_start + 34
Thread 3:: com.apple.CFSocket.private
0   libsystem_kernel.dylib           0x94ec584e __select + 10
1   com.apple.CoreFoundation         0x91a58b3a __CFSocketManager + 906
2   libsystem_pthread.dylib          0x9aaebc25 _pthread_body + 138
3   libsystem_pthread.dylib          0x9aaebb9b _pthread_start + 162
4   libsystem_pthread.dylib          0x9aae8e32 thread_start + 34
Thread 4:
0   libsystem_kernel.dylib           0x94ec58f6 __semwait_signal + 10
1   libsystem_c.dylib                0x94a31c02 nanosleep$UNIX2003 + 218
2   org.audacityteam.audacity        0x0001e057 AudioThread::Entry() + 151
3   libsystem_pthread.dylib          0x9aaebc25 _pthread_body + 138
4   libsystem_pthread.dylib          0x9aaebb9b _pthread_start + 162
5   libsystem_pthread.dylib          0x9aae8e32 thread_start + 34
Thread 5:
0   libsystem_kernel.dylib           0x94ec5e6a __workq_kernreturn + 10
1   libsystem_pthread.dylib          0x9aaeb72a _pthread_wqthread + 939
2   libsystem_pthread.dylib          0x9aae8e0e start_wqthread + 30
Thread 6:
Thread 7:
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x00000000  ebx: 0xa0b0a6d0  ecx: 0xbfffd60c  edx: 0x00000000
  edi: 0xa10641d4  esi: 0x00000006  ebp: 0xbfffd628  esp: 0xbfffd60c
   ss: 0x00000023  efl: 0x00000206  eip: 0x94ec569a   cs: 0x0000000b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
  cr2: 0xa0b08a00
Logical CPU:     0
Error Code:      0x00080148
Trap Number:     132
Binary Images:
    0x1000 -   0xbe1ff7 +org.audacityteam.audacity (2.1.3.0 - 2.1.3.0) <4CC2A30A-9EC8-32DD-93BE-2B27EFD3A986> /Applications/Audacity.app/Contents/MacOS/Audacity
 0x1092000 -  0x112dff3 +libwx_osx_cocoau_release_xrc-3.0.0.2.0.dylib (3) <4205ED8D-DD3D-3B5F-97CF-56ABE8413C95> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_xrc-3.0.0.2.0.dylib
 0x1166000 -  0x1178fff +libwx_osx_cocoau_release_webview-3.0.0.2.0.dylib (3) <307435F3-CE16-3BA1-8964-E717ABA35C87> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_webview-3.0.0.2.0.dylib
 0x1188000 -  0x1211fff +libwx_osx_cocoau_release_html-3.0.0.2.0.dylib (3) <D976D586-BE56-3ECA-8D1B-1B62566A7898> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_html-3.0.0.2.0.dylib
 0x1255000 -  0x1272ff3 +libwx_osx_cocoau_release_qa-3.0.0.2.0.dylib (3) <8D24B71A-180E-3E8E-BBC0-40A1A0824B79> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_qa-3.0.0.2.0.dylib
 0x1285000 -  0x1368ff7 +libwx_osx_cocoau_release_adv-3.0.0.2.0.dylib (3) <49A620D7-6681-3B34-BFCB-B1DED56A8AE8> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_adv-3.0.0.2.0.dylib
 0x1404000 -  0x17efffb +libwx_osx_cocoau_release_core-3.0.0.2.0.dylib (3) <5F6E448C-0082-306C-AF44-255B5B9E5C91> /Applications/Audacity.app/Contents/Frameworks/libwx_osx_cocoau_release_core-3.0.0.2.0.dylib
 0x19c5000 -  0x19eeffb +libwx_baseu_release_xml-3.0.0.2.0.dylib (3) <C514C21F-BBF0-3890-BA35-0AD79E6FA8B6> /Applications/Audacity.app/Contents/Frameworks/libwx_baseu_release_xml-3.0.0.2.0.dylib
 0x19fb000 -  0x1a23ffb +libwx_baseu_release_net-3.0.0.2.0.dylib (3) <6DDF42ED-213E-3333-A075-DB4BA44BFA27> /Applications/Audacity.app/Contents/Frameworks/libwx_baseu_release_net-3.0.0.2.0.dylib
 0x1a39000 -  0x1bc8ff7 +libwx_baseu_release-3.0.0.2.0.dylib (3) <73C0C4E1-6362-33B3-9499-C999B3D7730D> /Applications/Audacity.app/Contents/Frameworks/libwx_baseu_release-3.0.0.2.0.dylib
 0x1c40000 -  0x1c69fff  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <597AA516-9AC9-3B20-9E32-FF8BF662554A> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
 0x1c7c000 -  0x1cb5ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <20E11181-3421-3D46-97C0-347F68ED816A> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
 0x1cd8000 -  0x1cefffb  libexpat.1.dylib (12) <751B1CA1-D871-37AA-BE43-4131FF8B7747> /usr/lib/libexpat.1.dylib
 0x6f4f000 -  0x6f9cff7  com.apple.CloudDocs (1.0 - 321.10) <9343D667-13D3-379C-BDCA-7D6D6B8CC7E5> /System/Library/PrivateFrameworks/CloudDocs.framework/CloudDocs
 0x6fef000 -  0x6fefffb +cl_kernels (???) <3762E38B-B631-403D-B0F3-BD6B963231F3> cl_kernels
 0x6ffe000 -  0x6ffeff9 +cl_kernels (???) <DB9F7548-FDDD-40CD-A325-685CF808B082> cl_kernels
 0xbeea000 -  0xbeeefff  com.apple.audio.AppleHDAHALPlugIn (272.18.3 - 272.18.3) <0B46A443-2AA6-3F19-84EA-A22C023FBE88> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
 0xc000000 -  0xc0ebff7  unorm8_bgra.dylib (2.4.5) <9DE4095F-AAC1-3078-B3A6-197721E4BC8F> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
 0xc349000 -  0xc349fff  com.apple.quartzframework (1.5 - 1.5) <1AE25E65-02FC-35B5-A1C8-734EC12DA3C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
 0xc57c000 -  0xc581ff7  libgermantok.dylib (17) <61AF7535-B2FE-3DCE-8B86-01571DA9DF35> /usr/lib/libgermantok.dylib
 0xc585000 -  0xc586ff7  com.apple.AddressBook.ContactsData (9.0 - 1579) <600412DD-1C40-3017-957B-0A4CD28EDEA9> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData
 0xc5a9000 -  0xc7ffffb  com.apple.audio.units.Components (1.12 - 1.12) <CDBD7615-8B56-3CA5-AA0A-8BB4CCDD11B3> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
 0xc9a4000 -  0xc9a5fff  com.apple.marco (10.0 - 1000) <3C7C31E8-D821-3212-AABF-156373EEBC2B> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
 0xc9ac000 -  0xc9b7fff  com.apple.AppleFSCompression (68.30.1 - 1.0) <E4E0C66A-2960-3E98-839C-128A64889545> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
 0xd533000 -  0xd534ff7  com.apple.diagnosticlogcollection (10.0 - 1000) <070E9DD0-94CD-3B04-8CCC-BD4C9CCE9224> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
 0xd53b000 -  0xd53dfff  com.apple.SafariServices.framework (10602 - 10602.2.14.0.7) <1B0C4C6D-4E6F-3D61-8B98-272EBAACD734> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
 0xd625000 -  0xd654fff  com.apple.datadetectors (5.0 - 286.13) <5476CAA4-D576-3331-A288-8572669D0C4B> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
 0xd66e000 -  0xd6d9fff  com.apple.ids (10.0 - 1000) <F9295B64-1C85-38C6-8457-4F89C4810417> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
 0xd6f9000 -  0xd71efff  com.apple.idsfoundation (10.0 - 1000) <DE7F9CA7-C38A-3748-8353-48FB32978226> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
 0xd737000 -  0xd743ff7  com.apple.commonutilities (8.0 - 900) <D3A25849-4424-3530-80C6-C52773D0545A> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
 0xd74e000 -  0xd759fff  com.apple.IntlPreferences (2.0 - 150.1) <0D588220-0B96-31F2-A21E-E4E9A14C3A19> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
 0xd8a1000 -  0xd8cafff  com.apple.facetimeservices (10.0 - 1000) <F5969B68-D4B6-3FFF-A4D3-9C2A38B51CE0> /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTServices
 0xd8db000 -  0xd8e9fff  com.apple.AddressBook.ContactsFoundation (9.0 - 1579) <E847D78F-D27E-31E7-AC84-DF41D1B5073B> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
 0xdcff000 -  0xdd09fff  com.apple.DirectoryService.Framework (10.10 - 187) <2B85DFE4-6EBF-34FE-AA7B-165BDDE72267> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
 0xdd12000 -  0xdd19ff3  com.apple.phonenumbers (1.1.1 - 105) <19A59F22-DD76-345E-AF7B-96405D71DB5A> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
 0xf48a000 -  0xf4f9ff3  com.apple.imfoundation (10.0 - 1000) <EBAA12A6-0158-3012-8B74-9DF2D7086AB2> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
 0xf52e000 -  0xf531fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <D9A10615-D6FA-3861-8094-6D97EB009D08> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
 0xf537000 -  0xf541fff  com.apple.DisplayServicesFW (2.9 - 372.1) <01C3D99D-7F75-3401-95E8-5175E028EE21> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
 0xf814000 -  0xf856ff7  com.apple.bom (14.0 - 193.6) <8A66E20C-4275-3861-9C2D-F2F804105FBB> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
 0xf868000 -  0xf888ffb  com.apple.addressbook.vCard (9.0 - 1579) <88627874-568E-3EB6-B037-47333F542FB6> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
 0xf8a6000 -  0xf8c2ff7  com.apple.aps.framework (4.0 - 4.0) <AE077C19-E36A-3903-8D4E-AC035E2D1819> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
 0xf8d9000 -  0xf90affb  com.apple.securityinterface (10.0 - 55058) <95726911-E181-3115-8451-EE1FA35A2937> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
 0xf929000 -  0xf94fff7  com.apple.quartzfilters (1.10.0 - 1.10.0) <5712F712-4A1C-35BF-AE1D-F55DA1D9877D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
 0xfe00000 -  0xfef5ff7  com.apple.QuickLookUIFramework (5.0 - 675.43) <B9BC6567-C012-361F-B9EE-93E327B1BB8F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x149dc000 - 0x14c47ff7  com.apple.AddressBook.framework (9.0 - 1579) <78AD8E14-94C0-3BD1-B34D-E16600FF2129> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x14dfd000 - 0x14e5eff3  com.apple.QuickLookFramework (5.0 - 675.43) <F6AA56C4-E32F-36B9-A4F7-C352CBE14FBB> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x14e96000 - 0x15409ff7  com.apple.QuartzComposer (5.1 - 332.1) <729DEB37-9976-38E2-8779-F74A8DDE54DC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x15670000 - 0x1571bff7  com.apple.PDFKit (3.1 - 3.1) <1FF5D72C-37F5-35DB-AF77-5EB66F1AC179> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x1576c000 - 0x159f8fff  com.apple.imageKit (2.6.1 - 850) <AFA54FD2-D335-34AC-8396-C73DECF25841> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x15ba1000 - 0x15c2bfff  com.apple.CorePDF (4.0 - 4) <3B850ADF-07F7-38A7-9991-C1C81A29C67F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x15c6c000 - 0x15cc4ff3  com.apple.ImageCaptureCore (6.3 - 6.3) <49CF4680-ABFB-33FB-B939-5B6524EC66FA> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x8fee1000 - 0x8ff14e83  dyld (353.2.4) <26A0639E-9BD3-313A-A0BF-219FA2A7F6F3> /usr/lib/dyld
0x90008000 - 0x90014fff  com.apple.CrashReporterSupport (10.10 - 631) <9A6DF8E2-AE0F-3919-889A-CD7F79ABD6EC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x90015000 - 0x90075fff  com.apple.AppleVAFramework (5.0.31 - 5.0.31) <5D44FEB4-3BE6-3FE0-B278-78C3A10AB1A3> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x90076000 - 0x90084ff3  com.apple.opengl (11.1.6 - 11.1.6) <4F03A0A3-8437-323A-8E12-A389D73C4505> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90085000 - 0x900d9ff7  com.apple.HIServices (1.22 - 523) <56F4ED21-FE4C-3F33-A425-D64E69B12F05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x900da000 - 0x90364ff3  com.apple.security (7.0 - 57031.40.8) <986D75F2-F340-3DCA-9801-9F2F4DD33E00> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x90365000 - 0x90380ff7  com.apple.CFOpenDirectory (10.10 - 187) <E2363E55-6C66-3F21-9A05-421D63DF9FF2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x90381000 - 0x90382fff  liblangid.dylib (117) <34A0F807-755F-300B-B01F-AABAE3838451> /usr/lib/liblangid.dylib
0x90383000 - 0x904f8ff7  com.apple.QTKit (7.7.3 - 2890.10) <F3D6EF83-B35B-368F-9CDE-E6C5AE67FE4C> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x904f9000 - 0x90513ff7  liblzma.5.dylib (7) <D0BC984D-5B33-328C-8F1E-7E9C41813433> /usr/lib/liblzma.5.dylib
0x90514000 - 0x90516fff  com.apple.loginsupport (1.0 - 1) <BA8EEAD0-8E97-3219-949B-50AE67F8869E> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x90517000 - 0x90540fff  libsystem_info.dylib (459.40.1) <4827C088-2BF0-397F-B9FA-0F91BDF64637> /usr/lib/system/libsystem_info.dylib
0x90541000 - 0x90657ff3  com.apple.desktopservices (1.9.3 - 1.9.3) <544FDA55-063A-3787-A55A-A54290E4BE6E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90658000 - 0x90660fff  com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <FDCAA783-356F-3CA4-B960-16555CD7E34A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x90661000 - 0x90667ff7  com.apple.MediaAccessibility (1.0 - 61) <81E9530E-882C-313C-A4D5-2F43EB569E4F> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x90668000 - 0x90681ff7  libsystem_malloc.dylib (53.30.1) <1438C1B7-5CD0-3A01-ACF8-BFC4012541B9> /usr/lib/system/libsystem_malloc.dylib
0x90682000 - 0x9068aff7  libCGCMS.A.dylib (788.3.5) <662A2443-422F-3500-BD1A-C22C1DA3C9FF> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x9068b000 - 0x90697ff7  libcsfde.dylib (471.30.1) <29155D7B-2C73-38E5-9A82-609A759EB03D> /usr/lib/libcsfde.dylib
0x90698000 - 0x9069afff  libsystem_coreservices.dylib (9) <20E66A47-8D67-344A-A393-73926F0E5FB2> /usr/lib/system/libsystem_coreservices.dylib
0x9069b000 - 0x906a8ff7  com.apple.OpenDirectory (10.10 - 187) <6323752A-8CBE-3EF0-9934-F587EC24EF16> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x906ae000 - 0x906d7ffb  com.apple.shortcut (2.14 - 2.14) <4A035852-8510-383E-800E-8F78E88E89EB> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x906d8000 - 0x906feff3  libc++abi.dylib (125) <E9AF8CA1-D54D-37E3-8363-A3E8C0840F71> /usr/lib/libc++abi.dylib
0x906ff000 - 0x9076aff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <632A811D-4706-3ED7-85E3-DD2CDB47CF8F> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x9076b000 - 0x9078dfff  com.apple.MultitouchSupport.framework (264.6 - 264.6) <83627B4D-8948-35A7-A76B-7F10AC70B468> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9078e000 - 0x907c1fff  com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <709E9F1B-D266-399B-9A4B-3785BBF64E01> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x907c2000 - 0x9083fff3  com.apple.framework.IOKit (2.0.2 - 1050.20.2) <84299E45-C5F3-365F-AC1B-0EAFF8057112> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90840000 - 0x90b9aff7  libmecabra.dylib (666.7) <55A50B97-92D3-3DDC-8E3A-58BC5FFE5E3F> /usr/lib/libmecabra.dylib
0x90b9b000 - 0x90c91ff7  libxml2.2.dylib (26.12) <B7B9B885-27E6-31BD-A5CD-F7875EBEC585> /usr/lib/libxml2.2.dylib
0x91641000 - 0x91641fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <C2367B5B-AE20-3084-A864-104743BE478E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91642000 - 0x9169dffb  libTIFF.dylib (1247) <4D9AB800-ED01-37E9-A06A-5A3FABB365CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9169e000 - 0x91990ffb  com.apple.CoreImage (10.3.5) <D993E623-6DC1-3FC1-9FA5-1A70FBE43574> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x91991000 - 0x91d45ff7  com.apple.CoreFoundation (6.9 - 1153.18) <267B1002-C755-37B4-95CD-92358CF994B8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x92785000 - 0x9278efff  com.apple.AppleSRP (5.0 - 1) <83C56D61-E2BF-3D34-93A6-DA0784BDD61A> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x9278f000 - 0x92791fff  com.apple.securityhi (9.0 - 55006) <FC96FF16-D834-3EDA-9B61-5F7726174569> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92792000 - 0x92794ff3  com.apple.EFILogin (2.0 - 2) <00F6D57F-5B4F-373E-BBFF-D19E1E7F87E6> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x92795000 - 0x92a2cfff  com.apple.CoreData (111 - 526.3) <93295B9D-6C48-3919-8B9C-A4291D3522CE> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x92a2d000 - 0x92a53ffb  libPng.dylib (1247) <3041B0DB-4718-34D0-BC2A-2620A1B08719> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x92a54000 - 0x92a5bfff  com.apple.XPCService (2.0 - 1) <9A59D63D-446A-33A4-BB21-56E42417DA93> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x92a5c000 - 0x92a5efff  libCVMSPluginSupport.dylib (11.1.6) <27E51D50-D030-3BA8-AF6E-4317A2003944> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x92a5f000 - 0x92a6effb  libxar.1.dylib (255) <4FF7DB6F-3232-302F-94BC-F1188F78AF25> /usr/lib/libxar.1.dylib
0x92a6f000 - 0x92a74ff7  libmacho.dylib (862) <48DE74F8-09E3-344F-A82F-665083A3BF8F> /usr/lib/system/libmacho.dylib
0x92a75000 - 0x92a7eff7  libsystem_notify.dylib (133.1.1) <B8503E99-214B-3AC3-A7CA-CC837ABD7B25> /usr/lib/system/libsystem_notify.dylib
0x92a7f000 - 0x92abffff  com.apple.Symbolication (1.4 - 56045) <BE1C4846-DA11-365D-9B46-3FF130401839> /System/Library/
Apple Audacity crash report.rtf.zip
(19.98 KiB) Downloaded 11 times
Reason: wrap crash report in Code tags
TonyP
Next
Return to Mac OS X
Who is online
Users browsing this forum: xanadukr and 5 guests
