EDIT commands graying out
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by Eustacce » Tue Aug 01, 2017 9:11 pm
I use MacOS Sierra, Version 10.12.5 and Audacity 2.1.2. I am attempting to copy and past sections from one track to another. Most of the time the copy command works, but when I open up the receiving track, Edit has grayed out cut, copy, and paste. What am I failing to do?
Eustacce
Re: EDIT commands graying out
Permanent link to this post Posted by kozikowski » Tue Aug 01, 2017 9:16 pm
As a fuzzy rule, tools turn gray if you're in Pause or anything but Stop.
Permanent link to this post Posted by billw58 » Tue Aug 01, 2017 11:07 pm
As Koz points out, you must be in Stop mode to do any editing.
What do you mean by "open up the receiving track"?
If there is simply a cursor position in a track (not a selected region) then Copy and Cut will be disabled as there is nothing to Copy or Cut.
Paste may be disabled as described in this manual page if there is no room to paste the audio.
-- Bill
billw58
Permanent link to this post Posted by Eustacce » Wed Aug 02, 2017 3:10 pm
Thanks so much! I knew my problem had to be a simple mistake, but I needed your help to realize what it was. Everything seems copasetic now.
Eustacce
Eustacce
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
