Audacity 2.1.1 problems with LAME library recognition.
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by SheerGold » Mon Jul 31, 2017 9:04 am
I have an iMac with 10.5.8.
I have downloaded Audacity 2.1.1 ( it seems this is the only version suitable for 10.5.8).
I downloaded Lame from the correct page:
http://lame.buanzo.org/#lameosxdl
And I followed the instructions on the correct page:
http://manual.audacityteam.org/man/faq_ ... g_ins.html
I went to Audacity Preferences/Libraries to locate the Lame file, initially Audacity finds the Lame file, and I clicked on the file.
But Audacity still will not export to mp3.
I also tried putting "libmp3lame.dylib" into the folder where I have Audacity installed. But Audacity still will not export to mp3.
Obviously I have tried restarting the Mac.
Anyone have any ideas?
SheerGold
Operating System: OS X 10.6 Snow Leopard or earlier
Re: Audacity 2.1.1 problems with LAME library recognition.
Permanent link to this post Posted by billw58 » Mon Jul 31, 2017 4:09 pm
When you say "Audacity will not export to mp3" what exactly are you seeing?
In the Save dialog that comes up when you choose File > Export Audio, what do you see when you click on the "Format" dropdown menu?
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
