High/Low Pass Filter?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by Bibblyboy » Sun Jul 30, 2017 11:52 pm
I'm trying to edit something, I clicked on Effects to use the High Pass Filter option, but it isn't listed. In fact, several functions aren't listed, and the effects only go down to Wahwah. How do I get to the High Pass Filter option? Quick answer please.
Bibblyboy
Re: High/Low Pass Filter?
Permanent link to this post Posted by steve » Mon Jul 31, 2017 12:13 am
Ensure that you are using the current version of Audacity (2.1.3 at time of writing) and you have installed it according to the instructions: http://www.audacityteam.org/download/mac/
Do not attempt to run Audacity directly from the DMG.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
