Can only export part of project
I can Export from 2.1.3, but can only Save 36:23 from a 1:20:00 track. I’m using Sierra. Can anyone help?
Try exporting it in a more reasonable format, such as 16-bit, 44100 Hz.
To set the sample rate, select 44100 in the “project rate” box in the lower left corner of the main Audacity window.
Thanks, Steve, but I definitely want 192000 for this project.
The maximum size for a normal WAV file is 4 GB https://en.wikipedia.org/wiki/WAV#Limitations
so either you need to use a different format, or split the project into multiple files.
Great! I believe you’ve supplied the solution. I’ll try it. Thank you!
