Audacity debug reports
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by planetlizz » Thu May 18, 2017 11:20 pm
NO RUSH NO RUSH
Hello,
Audacity 2.1.3
Macbook 10.7.5
One more look at my open Audacity before commenting. ok ..... so....
Debug reports with nearly every use. Seems to occur after a couple hrs of use. Same scenario each time.
This is (vo) eLearning, therefore, multiple tracks in a single window. up to (5-10) 3-5 minute recordings. tho at that point i am likely to save & start anew (its called learning from the past) course i diligently save as I go now.
Problem occurs almost always during playback where its "play stop select delete play stop copy paste play stop" pretty rapid fire. then ill tap the space bar (to stop playback) it doesnt respond. UH OH HERE WE GO AGAIN! the experience then becomes one of playback wont stop/no other commands can be given BUT with each tap of the space bar/mouse click (of the STOP button for ex) emits my mac's "error" sfx ... as the playhead just continues to roll into oblivion! NO CHOICE BUT TO RIDE IT OUT! Like it has a mind of its own or is POSSESSED!!! sfx reminds me of the bong BONG bong BONG bongggg from Close Encounters of the 3rd Kind ........haha remember THAT kiddies??!!! :lol: Anywho after some time it eventually stops/DEBUG appears. (always complete & return the report.) :D
I exit all other programs including browsers/drive, giving audacity all the room it needs. it never recovers.
Thanks!!!!!!!! I checked the board first .. nada
Liz
NO RUSH ... its not killing me just annoying me THANK GOD FOR AUDACITY RECOVERY! omg thank you!
What questions do you have for me (bc I know you will!!!!) :roll:
planetlizz
Operating System: OS X 10.7 Lion
Re: Audacity debug reports
Permanent link to this post Posted by Gale Andrews » Fri May 19, 2017 10:50 am
New topic started, split from http://forum.audacityteam.org/viewtopic.php?f=47&t=95512.
Please do not jump into someone else's topic even if there seems slight relevancy. You are not using the original poster's machine. It is not fair on us or the original poster to deal with his circumstances and yours in the same topic.
Thank you for understanding.
Permanent link to this post Posted by Gale Andrews » Fri May 19, 2017 11:04 am
Please could you give us more information to go on. Attach one of the debug reports. See http://manual.audacityteam.org/man/help_menu.html#data and how to attach files to forum posts.
If there is a Mac crash report for Audacity at /Applications/Utilities/Console.app, please attach that too.
Please tell us exactly what audio device you are using for playback (make and model number if it's an external device you attach to the computer). If it's an external device, does it connect by USB or Firewire?
You could try pressing the keys more slowly. In particular if you select by mouse, release the mouse before using a keyboard shortcut such as delete.
Have you tried this: Quit Audacity. Open Finder then Go menu > Go to Folder. Paste or type:
Code: Select all
~/Library/Application Support/audacity/
In that "audacity" folder, delete the file "audacity.cfg". This deletes your old settings and starts with factory-fresh ones.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
