How to install VoxReducer in Mac
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by Humbardi » Thu May 18, 2017 5:26 pm
Dear friends :
I am new in Audacity , and I found that there is a Vocal Removal Plug-in named VoxReducer, and I want to try it. I downloaded it , and I got a file named : voxReducer1_2full.
When I try to install it, I get an error message : "The Installer could not install because there was no software found to install "
May you , please , give me some directions about the installation , to use VoxReducer in Audacity ?
Many Thanks in advance
Humbardi
Humbardi
Re: How to install VoxReducer in Mac
Permanent link to this post Posted by steve » Thu May 18, 2017 5:43 pm
Humbardi wrote:When I try to install it, I get an error message : "The Installer could not install because there was no software found to install "
VoxReducer is not our software. For VoxReducer support you need to use their support channel.
From a quick Google search, VoxReducer appears to be much the same as Audacity's "Vocal Remover" effect (http://manual.audacityteam.org/man/vocal_remover.html)
You could also try the "Vocal Reduction and Isolation" effect: http://manual.audacityteam.org/man/voca ... ation.html
Return to Mac OS X
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
