Error message from Crossfade Tracks effect
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Re: Error message from Crossfade Tracks effect
Permanent link to this post Posted by Gale Andrews » Sat May 13, 2017 12:44 am
rgnewsman wrote:Is it possible this could be an anomaly?
The word Colorado was perplexing me. I tried using the crossfade with a new selection of music and it worked.
Could that Colorado file have been corrupted and possibly prevented the crossfade?
If so I am sure Steve would like to see the file(s) you were using for the crossfade when you had the problem. But had you already deleted the old pluginsettings.cfg file?
If you import only the Colorado file then File > Edit Metadata..., is there any metadata that says "Colorado"? What is the full path to the file including subfolders?
Permanent link to this post Posted by rgnewsman » Sat May 13, 2017 5:07 am
I'll have to check. I'll let you know.
I'm out of town for several days.
I'll check when I return and let you know.
Thanks so much for the help.
rgnewsman
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
