Error message from Crossfade Tracks effect
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by rgnewsman » Thu May 11, 2017 9:31 pm
HELP PLEASE WITH CROSSFADE EFFECT.
I'm somewhat new to audacity but absolutely love it.
I'm having some problems though cross fading tracks.
I've laid out some screen shots to help explain my problem.
I'm working on a Mac Mini with Sierra Operating system.
And Audacity 2.1.3
I highlight the tracks to crossfade
Select the crossfade function from effects.
Select the fade type, click ok an get this Nyquist dialogue box that I don't understand.
And when I click ok nothing happens to the tracks. The crossfade effect has no effect on the selected tracks.
I'm sure it's operator error.
Can any tell what I'm doing wrong.
I've checked online tutorials but see nothing.
Many Thanks
Selected effect
Screen Shot 2017-05-11 at 4.21.48 PM.png (56.72 KiB) Viewed 499 times
Nyquist ??? I don't know what this is.
Screen Shot 2017-05-11 at 4.22.08 PM.png (37.78 KiB) Viewed 499 times
Selected track
Screen Shot 2017-05-11 at 4.21.24 PM.png (151.72 KiB) Viewed 499 times
Last edited by Gale Andrews on Thu May 11, 2017 11:41 pm, edited 2 times in total.
Reason: placed images inline so that they fit Forum layout
rgnewsman
Re: Error message from Crossfade Tracks effect
Permanent link to this post Posted by steve » Thu May 11, 2017 9:57 pm
Try clicking the "Debug" button rather than the "OK" button. I expect it will show an error message. Copy and paste the error message (all of it, as text) into your reply.
Also, when you have a new question, please start a new topic and give it a relevant title.
Permanent link to this post Posted by rgnewsman » Thu May 11, 2017 10:09 pm
Thanks for the help Steve.
It was lengthy error message.
Here it is in three parts.
Thanks so much.
Screen Shot 2017-05-11 at 5.03.58 PM.png (40.74 KiB) Viewed 501 times
Screen Shot 2017-05-11 at 5.04.13 PM.png (33.42 KiB) Viewed 501 times
Screen Shot 2017-05-11 at 5.04.37 PM.png (42.28 KiB) Viewed 501 times
Reason: Post moved to correct topic and retitled
rgnewsman
Permanent link to this post Posted by steve » Thu May 11, 2017 10:25 pm
Have you been trying to modify the plug-in?
Also, please post error messages at text rather than as a screenshot.
Permanent link to this post Posted by rgnewsman » Thu May 11, 2017 10:27 pm
No, I wouldn't know how to modify the plug in.
I've literally just gone through the steps I outlined in the first post.
rgnewsman
Permanent link to this post Posted by steve » Thu May 11, 2017 10:37 pm
Well it looks like someone or something has modified the plug-in file, because the word "COLORADO" does not exist in the "Crossfade Tracks" plug-in that we distribute.
Permanent link to this post Posted by rgnewsman » Thu May 11, 2017 10:51 pm
I searched for Colorado music in safari. I edited music, perhaps even titled Colorado in Audacity, but I'm not quite sure how that would have any effect on the plug-in.
Like I said, I have no clue how to modify the plug in.
I'm not even sure how I could have done that by accident.
To be honest, I'm not sure where the plug in is located, how to access it, or even what it does.
That said, can you explain where the plug-in is located and how I get it back to the factory default settings so I can use the crossfade feature?
Thanks so much for your help.
rgnewsman
Permanent link to this post Posted by steve » Thu May 11, 2017 11:18 pm
For a default installation, the plug-in will be in:
~/Library/Application Support/audacity/Plug-Ins
The plug-in is just one file, called "crossfadetracks.ny"
Please attach that file to your reply so that I can take a look at it. Hopefully that will cast some light on what is going wrong.
Permanent link to this post Posted by rgnewsman » Thu May 11, 2017 11:43 pm
Audacity is intuitive and user friendly which is what I love about it.
I'm not technologically savy enough to "tinker" or modify it.
Besides I use it because I like the features the way they are.
But you may be onto something as to why this isn't working.
I don't see anything listed as Audacity plug ins.
Here is the Library path.
I got there by going:
Library/Application support/audacity
The Plug-ins folder is missing.
The only folder there says, "libs"
Hopefully, that helps in solving the mystery.
Again, thank you very much.
Screen Shot 2017-05-11 at 6.32.16 PM.png (141.09 KiB) Viewed 492 times
rgnewsman
Permanent link to this post Posted by Gale Andrews » Thu May 11, 2017 11:58 pm
rgnewsman wrote:I don't see anything listed as Audacity plug ins.
Here is the Library path.I got there by going:
Wrong Library. Steve said to go to
Code: Select all
See the tilde (~). That means your user Library in your HOME folder. Use the Go > Go to Folder menu item in Finder to get there.
However I expect the plugin is more likely inside Audacity. Right-click or Ctrl-click over the Audacity application, and click "Show Package Contents". Open the "Contents" folder then look in the "Plug-ins" folder.
Next
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
