audacity 2.1.1 on a macos sierra 10.12.4 - removing vocals
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by cathsing1 » Thu May 11, 2017 8:30 am
Hi, i use Audacity to change pitches, slow tracks etc.. I've ever been able to remove vocals to produce a clear instrumental (if i cannot already by online as old track etc...) I'm not sure if i remove middle, vocal reduction, isolation etc?? I've tried but you can still hear vocal in background etc.... i really need a step by step please... Thank you.
cathsing1
Re: audacity 2.1.1 on a macos sierra 10.12.4 - removing voc
Permanent link to this post Posted by Gale Andrews » Thu May 11, 2017 1:09 pm
Please understand that removing vocals is not a given when all you have is the mix. You are trying to unbake a cake.
See: http://manual.audacityteam.org/man/tutorial_vocal_removal_and_isolation.html for some methods you can try.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
