exporting a audio file to mp3
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by Sterlingrose » Wed Apr 19, 2017 9:04 pm
Hi, I edited an existing mp3 file on Audacity and exported audio as mp3 to desktop on my Mac OS X El Capitan 10.11.3, and the Audacity is 2.1.3 version. I had to download the Lame.... plugin to Applications to do this, but everything seemed okay. But when I burned this file onto a CD, it won't play in a portable CD player, only plays on the computer?? What did I do wrong?
Sterlingrose
Re: exporting a audio file to mp3
Permanent link to this post Posted by steve » Wed Apr 19, 2017 9:12 pm
When making an audio CD, it's best to export as WAV rather than MP3.
For an audio CD that will play in most CD players, you need to select "audio CD" as the type of CD (not a "data CD").
This tutorial should be helpful: http://manual.audacityteam.org/man/burn ... _a_cd.html
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 8 guests
