First part of my audio is being cut off during recording
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Re: First part of my audio is being cut off during recording
Permanent link to this post Posted by steve » Wed Apr 19, 2017 5:44 pm
cameronsnicholls81 wrote:why is that functionality there if it affects the recording?
Many uses, including:
* Dictation - avoid long silences while thinking.
* Wildlife recording - recording animal / bird sounds without huge lengths of nothing.
* Band rehearsals - record the songs but not the (relative) silence between songs
* Environmental noise monitoring - how often do noisy trucks / planes / dogs / ...
* Audio note taking - ignore "thinking time" silences.
* Recording streaming audio - by setting the threshold level extremely low, the recording will run continuously while there is an audio stream active, reducing the need to trim silences.
* other....
Permanent link to this post Posted by cameronsnicholls81 » Thu Apr 20, 2017 5:12 am
Ok, I see. Thanks Bill.
cameronsnicholls81
Operating System: OS X 10.10 Yosemite
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
