Where are Lame files? [SOLVED]
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by j2e » Mon Apr 10, 2017 1:52 am
Using Mac 10.11.6 (El capitan) I can download the lame plug in but the library can't find it. Every time I try to export the files to MP3 I get the message that I need to download LAME. Any idea what is happening here?
j2e
Re: Where are Lame files?
Permanent link to this post Posted by Gale Andrews » Mon Apr 10, 2017 12:04 pm
j2e wrote:Using Mac 10.11.6 (El capitan) I can download the lame plug in but the library can't find it. Every time I try to export the files to MP3 I get the message that I need to download LAME. Any idea what is happening here?
Make sure you have Audacity 2.1.3 from http://www.audacityteam.org/download/mac/ (see the pink panel at the top of this page).
Then use the LAME 3.99.5 installer as instructed in the FAQ: http://manual.audacityteam.org/man/installing_and_updating_audacity_on_mac_os_x.html#maclame.
Re: Where are Lame files? [SOLVED]
Permanent link to this post Posted by j2e » Mon Apr 10, 2017 4:24 pm
Thank you, this seems to have worked. I think an old Audacity was hanging around.
j2e
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
