Audacity 2.1.3 dmg File Size Discrepancy
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by Lidia » Sat Apr 08, 2017 11:58 am
Hello, I just downloaded the latest version of Audacity 2.1.3 for Mac OS X.
The dmg file SHA-256 was correct, and the virus scan was clear on VirusTotal. However, the downloaded dmg file size is 34,280,783 bytes (34.3 MB on disk), but the Audacity website says it should only be 32.69 MB, includes help files. Just curious if it's safe to install?
Thanks,
Lidia
Re: Audacity 2.1.3 dmg File Size Discrepancy
Permanent link to this post Posted by Gale Andrews » Sat Apr 08, 2017 12:31 pm
If the SHA-256 shown on VirusTotal matches with what Audacity and FossHub say it is, then it is safe and correct. You can also recheck the SHA-256 on your Mac in the Terminal:
Code: Select all
shasum -a 256 <file name>
Permanent link to this post Posted by cyrano » Thu Apr 13, 2017 8:20 am
It's good to report anomalies...
But in this case, I think it is just the difference in counting bytes. Apple started counting 1 K bytes as 1.000 bytes. Other OS'es count this as 1.024 bytes. Hence the difference.
I don't remember exactly when Apple started doing this. Lion? Mountain Lion?
cyrano
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 10 guests
