System Audio Recorder not working
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Re: System Audio Recorder not working
Permanent link to this post Posted by Gale Andrews » Tue Apr 18, 2017 1:10 am
NelleB wrote:My audacity system audio recorder
Again, that application is nothing to do with us.
Macs do not intend you to record computer playback, so any application that tries to do this has to go through a lot of hoops.
Having different applications trying to record computer playback in competition with each other is a terrible idea and probably why none of them work. So uninstall all of these applications except one, and then try each one. I would just get rid of Apowersoft if you have not already do so.
You may need to uninstall kernel extensions to get properly rid of any of these. See the documentation that came with the application. Mac System Report (Apple Menu > About This Mac) might be able to tell you who claims to make the apps other than Soundflower.
If you want to get properly rid of Soundflower 2.0.b2 (perhaps to try installing it again) I think the commands to run in the Terminal are:
Code: Select all
sudo kextunload /Library/Extensions/Soundflower.kext
You will have to enter your admin password.
When the unload is successful
Code: Select all
sudo rm -r /Library/Extensions/Soundflower.kext
Restart your computer for the changes to take effect.
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
