Vamp plugins in Audacity 2.1.2
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by aconto » Wed Apr 05, 2017 7:15 pm
Hello everybody. I'm trying to use a melody extractor plugin from UPF called Melodia. It's a Vamp plug-in, so I have: created a vamp folder under Library/Plug-ins; copied all the Melodia files as requested; tried to activate the plugin by means of add plug-in under Audacity. It seems that Audacity doesn't see this vamp plug-in. I have tried also to use it with Sonic Visualizer which sees it but it doesn't work well. Any suggestions ? Thanks in advance !
aconto
Re: Vamp plugins in Audacity 2.1.2
Permanent link to this post Posted by steve » Thu Apr 06, 2017 10:13 am
aconto wrote:I have tried also to use it with Sonic Visualizer which sees it but it doesn't work well.
I see that on their website they demo Melodia in Sonic Visualize, so I'd guess that is as good as it gets (http://mtg.upf.edu/technologies/melodia).
You could try the current 2.1.3 version of Audacity: http://www.audacityteam.org/download/mac/
I'd suggest that you completely remove your current version of Audacity, including its settings, before installing 2.1.3, so as to eliminate the possibility of old settings interfering with this Vamp plug-in.
Also, see: http://manual.audacityteam.org/man/inst ... mp_install
Permanent link to this post Posted by Gale Andrews » Thu Apr 06, 2017 3:01 pm
Audacity only shows VAMP plugins that have outputs that can be displayed in a label track. Graphs and contours can't be so represented. So Melodia is not going to appear in Audacity.
Permanent link to this post Posted by aconto » Fri Apr 07, 2017 4:14 pm
Thanks
aconto
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
