Horizontal scroll.
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Horizontal scroll.
Permanent link to this post Posted by jjsparey » Thu Mar 09, 2017 8:48 pm
I'm scrolling horizontally through 2hrs and 15 minutes of audio looking for bird calls. At the moment I'm using shift+mouse wheel but it's not long before my fingers get tired (at which point I turn the mouse over and roll it along the desk).
Is there an easier to horizontal scroll than this? something like holding down a forwards key or something less mechanical than having to constantly rotate the mouse wheel?
Thanks.
jjsparey
Re: Horizontal scroll.
Permanent link to this post Posted by steve » Thu Mar 09, 2017 9:54 pm
Try the dot and comma keys (the keys with the "<" and ">" characters).
On their own they do a "short jump" left / right (default 1 s at a time).
With the shift key held down they do a "long jump" left / right (default 15 s at a time).
The length of the jumps is configurable in "Preferences > Playback" (these "jumps" can also be used while playing the audio).
Permanent link to this post Posted by jjsparey » Thu Mar 09, 2017 10:32 pm
I reckon that's solved the problem.
Now instead of a scrolling timeline, which can be tiresome to watch, it's a series of short static screens. Shift+> at the right zoom level seems to work well.
Thanks, Steve. That's going to make a big difference. Much appreciated.
jjsparey
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
