Help with Plugins - macOS Sierra
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: Help with Plugins - macOS Sierra
Permanent link to this post Posted by Gale Andrews » Fri Feb 17, 2017 12:57 pm
stevemc wrote:
If you want to try the RC1 release candidate of 2.1.3 and give us feedback about it, please visit https://www.fosshub.com/Audacity.html/.
I tried the build and it worked perfectly. Its nice the way its a single package instead of a folder now.
Thanks for testing. Yes, having the contents inside the bundle should help with Gatekeeper too.
Let us know if you lose access to plugins or LAME/FFmpeg after closing project windows, or other times while using Audacity. That is still possible.
Permanent link to this post Posted by stevemc » Fri Feb 17, 2017 7:05 pm
In my case I had a clean machine I installed to. I installed the ffmpeg and lame plugins after installing audacity. I then opened Audacity and went to Library prefs. The MP3 library version was already listed as LAME 3.98.2 and the ffmpeg was not but when I clicked locate i got a msg saying it was already found and so I clicked no and it was populated correctly. So in short I think this build works fine with LAME and FFMPEG.
Note: I noticed an odd behavior. If I opend Audacity via keyboard thru spotlight (typing Cmd+Space and typing Auadicity) I get an error dialog stating "The application "Audacity.app" can't be opened." yet Audacity did open just fine. But when I Click the Audacity icon in applications thru the Dock I do not see this error. The error has no effect and Audacity opened just fine. So minor nuisance.
stevemc
Permanent link to this post Posted by Gale Andrews » Sun Feb 19, 2017 2:05 am
Thanks for testing 2.1.3 RC1, stevemc.
stevemc wrote:Note: I noticed an odd behavior. If I opend Audacity via keyboard thru spotlight (typing Cmd+Space and typing Auadicity) I get an error dialog stating "The application "Audacity.app" can't be opened." yet Audacity did open just fine. But when I Click the Audacity icon in applications thru the Dock I do not see this error. The error has no effect and Audacity opened just fine. So minor nuisance.
Thanks, I logged this at http://bugzilla.audacityteam.org/show_bug.cgi?id=1593.
Permanent link to this post Posted by k2graphics » Mon Sep 18, 2017 8:34 pm
stevemc wrote:I'm so glad to sound this post. The "xattr command solution" solved my problem with seeing the nyquist plug-ins. I spent a couple of days off and on searching for a solution stumbling upon this page.
To save others time, I suggest that you add some information to the Mac OS download page and if possible the readme included in the download DMG (thought this may require new build so maybe that's not so easy). I see there is a "Known Issue" regarding security settings on the download page but the xattr solution is not shown and the one that is mentioned does not solve problem.
This is the OSX download page I'm referring to: http://www.audacityteam.org/download/mac/
Thanks, stevemc, for posting this info. And your link really helped | saved me from going in circles.
k2graphics
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
