Audacity not opening cleanly in OSX 10.11.1 Beta-with a CLUE
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: Audacity not opening cleanly in OSX 10.11.1 Beta-with a
Permanent link to this post Posted by wfried » Mon Nov 20, 2017 6:24 pm
Hello,
Similar to other users on this thread, when I launch Audacity in MacOS 10.13.1 High Sierra (same thing happened in Sierra), each time it opens I see an error that says:
"The application "Audacity" can't be opened."
I am launching it by pressing cmd-space and typing "Audacity" and pressing return.
I tried the instruction to reset the database by Cyrano and ran:
"/System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -kill -r -domain local -domain system -domain user ; killall Dock"
I then logged out of MacOS and logged back in, but this did not help.
I also tried deleting the file "~/Library/Application Support/audacity/audacity.cfg" and relaunching Audacity but it did not help.
Note the app does open and run when I launch it, it just shows the error message as well. So this is annoying but doesn't stop me from using Audacity.
wfried
Permanent link to this post Posted by steve » Mon Nov 20, 2017 7:46 pm
wfried wrote:Similar to other users on this thread
Not very similar. You have a more recent operating system, and (I hope) a much more recent version of Audacity.
wfried wrote:ach time it opens I see an error that says:
Is that all that it says? No reason why it can't be opened?
wfried wrote:Note the app does open and run when I launch it, it just shows the error message as well
That doesn't seem to make much sense. Have I got this right, the operating system says that it can't open Audacity, and then it opens Audacity?
Permanent link to this post Posted by wfried » Mon Nov 20, 2017 9:34 pm
Yes, that was the experience. Your comment about version made me check for an update, and upgrading from 2.1.3 to 2.2.0 fixed the problem!
wfried
Permanent link to this post Posted by steve » Mon Nov 20, 2017 9:52 pm
wfried wrote:Your comment about version made me check for an update, and upgrading from 2.1.3 to 2.2.0 fixed the problem!
Good news :)
I'll close this topic now as it's a year old.
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
